586,750 active members*
7,311 visitors online*
    May 2017
    82
    C code for button
    I am trying to do c code when adding a button. I want to add three buttons one to move x to 0 one to move y to 0 and one to move z to -.75. I tried the move command but when I move to my zero position and reset the zero then the move command to zero moves the amount i zeroed out not back to the new zero position. Tried other commands and get undeclared error messages.
    This should be easy i move axis to zero location with arrow buttons then press zero for all axis then after machine runs a program I want the user buttons to bring x and z back to zero. I use a .75 block to adjust z zero then move off the work piece and lower the z .75 and reset zero. I would like a button so I don't have to use the arrow buttons 12 times.
    Joe
    May 2006
    4047
    Re: C code for button
    Hi Joe,
    To move to GCode Coordinates rather than Machine Coordinate zero you might use GCode instead of C Code. Create a GCode file (MoveToZero.ngc) something like this:
    G0Z-0.75
    G0X0Y0
    M30
    Then configure the User Button to run that GCode File with:
    Attachment 432584
    You shouldn't really need to move to zero to set the origin instead simply set the GCode position to 0.75. You could do that with GCode to set the G92 Offset similar to above with:
    G92Z.75
    M30
    If you want to also move to the new zero for some reason you could also do this with:
    G92Z.75
    G0X0
    M30
    HTH
    TK
    http://dynomotion.com
    May 2017
    82
    Quote Originally Posted by mirocha View Post
    Joe
    Works great setup 4 buttons thanks
    Joe
    May 2006
    4047
    Hi Joe,
    Great. Thanks for taking the time to post back
    TK
  1. Replies: 2
    Last Post: 10-18-2019, 12:12 PM
  2. Accidentally deleted script code from set Z button...help?
    By canman77 in forum Mach Software (ArtSoft software)
    Last Post: 09-12-2018, 05:57 AM
  3. Think I need a better placed RED Button
    By rdsi in forum Tormach PathPilot™
    Last Post: 02-05-2017, 08:29 PM
  4. Momentary Button OEM Code
    By DrivenMachines in forum Mach Wizards, Macros, & Addons
    Last Post: 04-22-2016, 04:31 AM
  5. Help with button code please
    By tmead in forum Mach Wizards, Macros, & Addons
    Last Post: 10-30-2008, 02:43 PM
