586,058 active members*
3,568 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > BMC40 Positioning error
Results 1 to 7 of 7
    Mar 2019
    10
    hi again back with a new error
    trying to calibrate my bmc40 with utimax 3 control. it calibrates the axis fine but the x axis moves to its limit then as it moves back i get the error "error positioning to marker on x axis" ive tried numerous times but cant get past it i can move the axis without calibration and everythign moves as it should.
    anyone she any light on a way round this
    thanks in advance
    Apr 2019
    58
    Re: BMC40 Positioning error
    Limit switch not working on that axis
    Išsi?sta naudojantis SM-G960F Tapatalk 4 Lt
    Mar 2019
    10
    Quote Originally Posted by cnc-exit View Post
    It goes to the limit and stops and it appears on the screen to say its working. Once it reaches the limit it moves away from it in the calibration cycle and that's when it stops the motion and comes up with the above error
    Sent from my WAS-LX1A using Tapatalk
    Apr 2019
    58
    Ultimax 3 software version 2.15?
    Mar 2019
    10
    Hi cnc-exit i will have to check the software version and get back to you but its definetly ultimax 3.
    Apr 2019
    58
    Ir can bethat parameters not set good. You need make copy of harddrive.
    I have my copy that working.
    But soft must be same. Because key not work.
    [email protected]
    +37060022992
    May 2017
    58
    Quote Originally Posted by Bunje View Post
    thanks in advance
    I had a similar problem on a hurco hawk with max3. Ended up being a bad ground in the limit switch that never let the machine know it had come off the switch after making contact.
  1. Y axis positioning error
    By Brian L in forum Milltronics
    Last Post: 05-29-2012, 09:17 PM
  2. Error of positioning in a CNC Machine
    By Ashish B in forum CNC Machining Centers
    Last Post: 08-14-2011, 11:06 AM
  3. positioning error
    By kendo in forum Haas Mills
    Last Post: 12-16-2008, 02:50 PM
  4. HELP! Gross positioning error
    By crazeekev in forum Bridgeport / Hardinge Mills
    Last Post: 09-09-2008, 04:11 PM
  5. 320 Positioning Error
    By elogicca in forum Gecko Drives
    Last Post: 07-08-2008, 05:33 PM
