586,060 active members*
4,154 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Getting ovality above 30 micron for 138 did bore
    We have casting parts of thin wall and we are getting ovality of above 30 microns for 138 bore
    Re: Getting ovality above 30 micron for 138 did bore
    Quote Originally Posted by sagar1996 View Post
    Yes and I get a stomach ache after eating too many pancakes!
    This is a juvenile post.
    What do you need?
    What equipment are you using? Mill? Lathe? Dremel?
    What control?
    What are the cutting conditions?
    What is the setup like?
    Cutter used? Depths? Feeds and speeds?
    Castings made of what material?
    Pictures?
    Get it?
    Without further information, the only broad fixes I can come up with are slow your feed. Check squareness of machine. Squareness error causes ovality at 45 degrees to the axis. Some squareness can be fixed by proper machine leveling.
  1. Horizontal Machining Center - Ovality in Job
    By M.RISHIKESH in forum Uncategorised MetalWorking Machines
    Last Post: 08-18-2015, 07:06 PM
  2. Ovality achieved By electrode
    By Ashish B in forum EDM Discussion General Topics
    Last Post: 02-28-2011, 08:04 AM
  3. Reamed Hole ovality
    By Ramu in forum CNC Machining Centers
    Last Post: 04-04-2010, 03:07 PM
  4. Ovality issues for aluminium parts
    By Viru in forum MetalWork Discussion
    Last Post: 04-04-2007, 04:40 PM
