586,100 active members*
2,670 visitors online*
Results 1 to 7 of 7
    Dec 2005
    117
    Need a cylinder for a music box
    I am building a present for a friend and need a part built if it is feasible. I would like to build a music box and need a cylinder built. I am going to take an existing music box and use all of the parts except for the cylinder with the pegs. The pegs pluck the notes at the correct times to play the song. Just looking at some music boxes the cylinder is about .5-.75 inches in diameter and about and inch long. To build the cylinder first a piece of stock would need to be turned to the correct diameter. I think aluminum would be fine. Then on a mill with a rotary axis the cylinder would be incremented and drilled. I would later push some pins into the drilled holes. I can figure out where all the holes need to be drilled to play the song I just dont have the mill to make it myself
    Any Idea how difficult it would be to build this part?
    Thanks Again
    Dan
    Dec 2005
    390
    Super cool idea! Should not be terribly difficult for someone with a CNC mill and CNC rotary table. Would be interesting to know how they used to be built though. Oh, just noticed the dimensions you have listed... going to be some pretty small holes and pegs...
    Dec 2005
    117
    Quote Originally Posted by wildcat View Post
    I Just looked at a cylinder in a music box and it is small . I think the pegs would have to be a stiff music wire.
    Seems like a reasonable thing to do on a 4 axis mill.... You may want to provide a list of hole locations with X axis and A axis specified rather than a model. It would be pretty easy to write a G code program that way.
    Make sure you do one yourself with a drill press to test your hole/pin methodology first.
    You will need to decide if you will use spring pins, or dowel pins with a press fit. You might need to build and arbor press jig. You might want to look at brazing or epoxy applied with a syringe.
    -Jeff
    www.JeffAlbro.net/cnc/
    Mar 2006
    69
    I've also seen these done by dimpling a thin sheet of bronze like metal and then wrapping it around a drum with end caps to keep it in place.
    Dec 2005
    117
    Thanks everyone for the feedback
    Does any body have a forth axis that would be interested in this project? I thought about making the cylinder out of copper so I can soldier in the pegs.
    Mar 2007
    51
    I will do it if you tell me where to drill the holes (I don't have time to research that). It would be a fun project. You need those every once and a while. I've drilled and reamed .0310 +/- .0001 holes for pins in the past. Will that do? However, .062 pins are easier to press in. I also have the pins.
    [email protected]
  1. Making music with plasma
    By cut more in forum Waterjet General Topics
    Last Post: 01-26-2007, 07:03 PM
  2. Music in the shop
    By dighsx in forum Community Club House
    Last Post: 06-26-2006, 04:53 AM
  3. Scanner Music CNC
    By Sanghera in forum Community Club House
    Last Post: 01-23-2006, 03:58 AM
  4. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
