586,067 active members*
5,288 visitors online*
    Jul 2014
    problem-Gross Positioning error c in z axis
    Hello.
    I'm a new bridgeport interact 2 users.
    When i power on machine.It starting and Referenced but after z axis move
    it stop and show error "gross position error c " and position on monitor not changed ,but z axis before stop , moves about 5 centimeter.
    I changed x and z axis servo but again machine error "gross position error c " after moving z axis.
    anybody can help me.
    Mar 2016
    325
    Re: problem-Gross Positioning error c in z axis
    What control system is it? (smells like heidenhain)
    Did U check the easuring elements connection (encoders)?
    Jul 2014
    tnc 151.Yes i change z and x servo encoder and again same error.
    Mar 2016
    325
    Did U replace encoders itself or with motors,
    This error may be caused by losening the encoders axis clutch from the screw.
    Letter C not necessary means Z axis.
  1. GROSS POSITIONING ERROR S B Alarm
    By Taza in forum Controller & Computer Solutions
    Last Post: 06-13-2019, 10:56 AM
  2. Gross positioning error A and D caused by Z axis, Interact 1 mk2 Tnc 151B
    By dickins11 in forum Bridgeport / Hardinge Mills
    Last Post: 02-09-2013, 01:45 AM
  3. Bridgeport Gross positioning error
    By Ogre4x4 in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2011, 11:45 PM
  4. Gross Positioning Error
    By Shanghyd in forum Bridgeport / Hardinge Mills
    Last Post: 01-21-2010, 02:33 PM
  5. HELP! Gross positioning error
    By crazeekev in forum Bridgeport / Hardinge Mills
    Last Post: 09-09-2008, 04:11 PM
