586,114 active members*
3,376 visitors online*
    Dec 2019
    4
    Multicam Connection issues
    Hello all,
    Firstly can i say how impressed i am with this forum and i think my head is going to explode with the wealth of knowledge on here.
    I have purchased a 5x10 Multicam Router.
    Currently it is running an M23 v4.03 board. built in 1996. (im able to utilise the stack of dell d630 laptops i have laying around for this beast)
    so obviously im running a serial connection.
    I have a business project in mind and i dont intend on cutting intricate parts so for now the M23 controller will be fine untill i have the money and the 'stones' to upgrade the hardware.
    My issue i hope will be simple for some of you experts.
    Machine connects to motion controller running Multicam S4 but when i try and find a cnc file the device states unable to connect to Host.
    This is baffeling me and i have tried as many settings as i dare.
    If i install multicam 3.5 software the host connects and i can choose a file. another baffeling part is the files i run through the older software do not cut to the correct size that i have expressed in Vetrics Aspire.
    I am hopeing somebody can point me in the right direction.
    if you need anymore information other them the following please let me know.
    M23 from 1996
    Windows xp, serial connection.
    multicam suite 4
    unable to connect to host
    Vectric to produce all gcodes or HPLT.
    Thank you in advance
    Jun 2010
    463
    Re: Multicam Connection issues
    To answer your questions above...
    You need Jobserver to communicate with that control board....Suite 4 will not connect.
    You'll need to get with Vectric, they should have a post for a Multicam machine...
    Attachment 433120Attachment 433120Attachment 433120
    Sep 2006
    118
    I 'm still running my circa 1999 MC Pro 102 with M24 board with Win 98 and MX32 and serial connection. I tried XP and Job Server and it worked irratically, but would lose connection at times. I've always used the Vectric ATC mm plt PP as I have a 2 spindle machine but the Vectric plt mm PP works too. It should also work with the Vectric MC GCode PP.
    Dec 2019
    4
    Thank you for your advice i had the machine connected with an issue on scale i have sat back looked at the g-code and machine settings and it seems to be running a dream.
    Time do get making before i get carried away with upgrades.
    I really appreciate everyones thoughts on the matter
  1. Replies: 3
    Last Post: 11-01-2018, 12:54 AM
  2. Multicam Program Issues
    By Stephen Samuels in forum Multicam Machines
    Last Post: 03-10-2013, 04:54 PM
  3. Multicam 5000 connection problem
    By rugbyal in forum Multicam Machines
    Last Post: 02-11-2013, 12:14 AM
  4. 610 plus connection issues
    By IdeaFactory in forum Multicam Machines
    Last Post: 09-27-2012, 05:01 PM
  5. Multicam MG103 connection problem
    By Romper in forum Multicam Machines
    Last Post: 06-21-2012, 08:02 PM
