586,103 active members*
3,672 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Physical Simulation in solid works
    Mar 2007
    hi,
    i am currently working in simulating springs in solidworks2005. I have created the spring by using helical path and coil dia. As the application of this spring requires square grounded spring, i have made the spring, flat at both ends for the required length. While simulating i was asked to selected to ends of the spring, free length and spring constant. But the problem is that i was able to select the one end but not so for the other end. pls give me the solution.
    Mar 2008
    Endpoints of springs
    I am experiencing the same problem as you. Once I chop off the ends to flatten the spring ends, I am unable to select endpoints for the Spring Physical Simulation. Does anyone have a solution to this problem?
    The problem is that after the ends are removed, the end of the spring is no longer at the origin and I can't see a way to fix that. I am still trying to figure out a way to add end points to the spring.
    J
    Feb 2007
    162
    Adding reference geometry such as a point or a plane, where needed, may satisfy the endpoint condition.
    It may also be necessary to create a sketch on the new plane to help.
    Scott
    Some of my best finds were in the trash....
  1. Replies: 5
    Last Post: 02-14-2007, 07:48 AM
  2. FABWorks and Solid Works
    By Access-Dennis in forum News Announcements
    Last Post: 10-26-2006, 04:15 PM
  3. Solid Works or AutoCad???
    By bill south in forum Uncategorised CAM Discussion
    Last Post: 03-03-2006, 05:06 AM
  4. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
  5. solid works cnc files
    By krustykrab in forum Mastercam
    Last Post: 06-19-2004, 03:53 PM
