586,058 active members*
3,366 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Break HF spindle with breaking resistor?
    Dec 2006
    112
    Hello,
    I am trying to break a 3kw 24000rpm 800hz spindle motor with a vfd and breaking resistor but the breaking resistor does not do much good, it takes about 10s to stop the spindle both with and without resistor.
    The only difference is that with the resistor the vfd does not report an error of over voltage during breaking so apparently its working somewhat.
    We have tried from 25ohm to 150ohm without any aparent difference.
    Could it be that the high frequency does not work well with the resistors? that the impendance in the resistor is to high to work with high frequencies?
    The VFD counts down to zero in 1-2s or whatever I set the decceleration parameter to and then the breaking resistor slowly break the motor to zero.
    15362
    Re: Break HF spindle with breaking resistor?
    Quote Originally Posted by jeeybee View Post
    Hello,
    What VFD Drive do you have
    Mactec54
    Dec 2006
    112
    Hello,
    Its a Machtric Z900 400v 2.2kw
    15362
    Hello,
    There is a new VFD listed everyday I would say you don't have the Braking Parameters setup correct the normal without a Braking Resistor is around 3 to 5 sec for that spindle
    So your spindle is 4 Pole ??
    Mactec54
    Dec 2006
    112
    Yes it is.
  1. who to buy a spindle from without breaking the bank
    By tkms002 in forum Commercial CNC Wood Routers
    Last Post: 01-27-2019, 12:48 AM
  2. Replies: 0
    Last Post: 11-30-2018, 09:54 AM
  3. Regenerative resistor in AC Spindle drive
    By jeck in forum Servo Motors / Drives
    Last Post: 06-07-2015, 02:34 PM
  4. Braking resistor for spindle VFD?
    By SwampDonkey in forum Spindles / VFD
    Last Post: 02-27-2014, 04:40 AM
  5. VFD & breaking resistor hookup
    By Cruiser in forum Phase Converters
    Last Post: 03-16-2009, 06:37 PM
