586,035 active members*
3,774 visitors online*
    Dec 2019
    Two Axis CNC Table
    Hello Everyone,
    I am working on a project that requires me to build an automated table. This table will function similarly to a CNC; however, it will only have a XY axis and it will not carve/mill any product. Essentially, it will be carrying an object that only weight one poind from point to point.
    This table needs to be a minumum of 2M x 2M (meters). I have never built a CNC machine before, but I under stand how they work. My plan is to use extruded aluminum for the frame. Does anyone have any recommendtions on products/manufacturing/suppliers parts I should use for the build?
    The budget is $3,000 excluding controls. I am incorperating my own control system .
    Jul 2018
    6339
    Re: Two Axis CNC Table
    Hi Agaylor - I suggest you use belts in such an application. A 10 or 16mm AT belt would work fine. Use 15 or 20mm rails and cars and NEMA 17 or 23 steppers. Depending on the speed / acceleration you want is the next question. If you look up the Maximus thread you will see CAD dwgs of this sort of thing. Its for A HD router but you can scale it back to a suitable extrusion size. Does it have a flat base or is it a high rail design with a void? If its $3000USD then you should have lots of change for this simple system....Peter
    May 2005
    1662
    A CoreXY type design might work although I've never spotted one scaled up to 2 meters.
    Link to an example used for moving a magnet below.
    https://docs.v1engineering.com/zenxy/
    Anyone who says "It only goes together one way" has no imagination.
    Dec 2013
    5717
    8020 extrusions are a good starting point. https://8020.net/?SID=dm001fm6uhqpj6t8hdmknghrt4
    For inexpensive rails and ball screws VXB Bearing is a good choice. OK quality https://www.vxb.com/
    McMaster is another good source for motion products, more expensive, but good quality products.
    https://www.mcmaster.com/linear
    https://www.mcmaster.com/ball-screws
    Ametric is another vendor I use for belts & pulleys. They also have screws and rails https://www.ametric.com/
    Jim Dawson
    Sandy, Oregon, USA
  1. Axis compensation table, 5-axis
    By Wolfpower in forum Haas Mills
    Last Post: 03-16-2016, 10:39 PM
  2. Tormach PCNC 1100 Fourth Axis Table as a C Axis
    By CNC-Dude in forum Tormach Personal CNC Mill
    Last Post: 01-08-2012, 12:49 PM
  3. EMC2 axis Z-axis homing and table
    By satovey in forum LinuxCNC (formerly EMC2)
    Last Post: 07-02-2011, 10:05 PM
  4. 5 Axis CNC with Rotary Axis on Table
    By Shooter7 in forum Commercial CNC Wood Routers
    Last Post: 09-20-2010, 04:33 PM
  5. Using X axis table moter for knee X axis
    By imatoymaker in forum Uncategorised MetalWorking Machines
    Last Post: 09-10-2007, 01:23 PM
