586,051 active members*
3,641 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Separate sub-forum for CNC's built with 3D-printed parts?
Results 1 to 7 of 7
    Dec 2008
    7
    Question Separate sub-forum for CNC's built with 3D-printed parts?
    It seems to be a rather obvious thing that is missing given the prevalence of cnc machines with 3D-prints tying together/mounting linear and structural parts and given that a lot of people only got around to(or had the equipment to) make a cnc after the advent of 3D-printing.
    "When lubrication fails violence prevails"
    Apr 2004
    5737
    Re: Separate sub-forum for CNC's built with 3D-printed parts?
    You're talking about CNC machines held together with pieces of plastic?
    Andrew Werby
    Website
    May 2005
    3920
    Quote Originally Posted by awerby View Post
    I’d be the first to say that plastic often sucks for machine parts but there are two interesting possibilities that are rather new to reality.
    First it is incredibly easy these days to get complex metal parts printed via services. The prices can often be surprisingly affordable.
    The second thing is that the available printable resins continue to increase resulting in far better mechanical properties.
    The price blem with either of these though is that building a router with off the shelf dimensional materials is already economical and quick. If one uses extrusions almost everything needed can come from a catalog. So I don’t see an issue here that demands 3D printing. For most builds it would be a negative in time and cost. Also retiring would suffer too.
    On the other hand I love seeing new approaches to builds. A 3D print for a spindle mount might work good enough to let the machines machine it’s permanent mount.
    May 2005
    3920
    Quote Originally Posted by MasterMaker View Post
    No need for a separate forum. More so I’m not sure you have a good history on DIY CNC.
    May 2005
    1662
    MasterMaker
    Like the MPCNC (Mostly Printed CNC) ?
    https://www.v1engineering.com/specifications/
    May 2005
    1662
    In America everything is available all the time and usually at reasonable shipping costs, or at least that's the feeling I get from the outside looking in. For example extrusions are not a cheap option in Canadian no-where-land, in some countries it will be closer to unobtanium.
    This video of a MPCNC is kind of impressive given the construction. How long a Dremel lasts put to that kind of use ? Probably not long.
    Edit/ The "Dremel" is actually a Kress, with real bearings etc.
    May 2005
    3920
    Quote Originally Posted by cyclestart View Post
    Extrusions aren’t exactly cheap here either. At least in Canada you can drive across the border for parts.
    That is an impressive video, thanks for the link. I especially like that the author highlighted the machines limitations honestly. Too many seem to overstate what they can actually do with a router in aluminum.
    In any event this highlights my point that a printed router is a good way to get a machine to build parts for a better router.
  1. Quote for three separate parts Brass or Steel
    By craynerd in forum RFQ (Request for Quote)
    Last Post: 07-24-2017, 03:56 PM
  2. Replies: 16
    Last Post: 08-25-2014, 03:33 AM
  3. 3D printed parts for CNC?
    By crimar in forum 3D Printer / 3D Scanner Discussion
    Last Post: 03-02-2014, 09:39 AM
  4. Need parts printed?
    By eaglezsoar in forum 3D Printer / 3D Scanner Discussion
    Last Post: 11-12-2012, 09:58 PM
  5. Separate and NUmber Parts For CNC Production
    By limbatus in forum Rhino 3D
    Last Post: 10-18-2009, 01:30 AM
