586,036 active members*
3,706 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > I bought a Haas Mini Mill basket case
Results 1 to 9 of 9
    Apr 2008
    61
    Hi everyone. I just bought a 2005 Mini Mill. It has had all the controls stripped from it. The mechanical condition looks good.
    My intended use is as a hobby mill making gun and airgun one-off parts, so speed is not a concern. It has the axis and spindle motors intact, but no electrical controls for them. I had planned to do a very simple Centroid Acorn conversion and use stepper motors on the axis, and a 3 hp induction motor on the spindle. Then sell off the stock motors. But, if there are non-Haas drives that can drive them, I might just reuse the stock motors.
    So, does anyone know if the spindle can be driven using a common VFD?
    Also, are there any commonly available servo drives that could work with my stock axis motors and use step and direction signals from the Acorn control?
    Thanks!
    Mike
    Sent from my SM-G960U using Tapatalk
    15362
    Re: I bought a Haas Mini Mill basket case
    Quote Originally Posted by fusion_crank View Post
    Thanks!
    Mike
    No you would not and can not use a VFD Drive to drive anything other than a AC 3 Phase motor
    Your axes motors are Yaskawa so are easy to Drive with there servo Drives just get the model number off the motor and I could find you the drives you need, most likely just need a Sigma II drive that suits the motor size
    A stepper motor setup on a Haas I hope you where joking
    Mactec54
    Mactec I thought those had a 3 phase motor on the spindle?
    I guess some pictures of the spindle motor and servo tags would go a long way here. Your z axis might be a different servo than the x and y (bigger with brake, maybe). Appropriate sigma drives shouldn’t be too hard to source once you identify the model #’s
    15362
    Quote Originally Posted by Sam_Beckham View Post
    Yes they do but you can't drive a VFD Drive with another VFD Drive if he does not have any VFD Drive then Yes he would have to use a Vector Drive for there stock spindle motor
    The servos are all the same size and yes the Z axis has a brake
    Mactec54
    Apr 2008
    61
    Hi again. I went to inspect the Mill today, but I couldn't get pictures of the motors. It should get delivered on Saturday, then I can collect more information after I pull the way covers. The machine itself looks pretty good, like it saw little use before it had the controls ripped out. It was purchased from a government auction. It had been used at the Redstone arsenal. The reason I think I was used little is the membrane keypad is in very good condition.
    The only component that was left in the controls box was the 320V power supply. Other than that it's as bare as Old Mother Hubbard's Cupboard. The 320V power supply isn't the Vector VFD, correct?
    I also found that the ATC carousel had been gutted as well.
    Thanks for your help.
    Mike
    Sent from my Acer Chromebook R11 (CB5-132T, C738T) using Tapatalk
    Apr 2008
    61
    Also, before they gutted the control, they left the head all the way at the top. Now, with no control, I can't just jog the head down to make it under my garage door because the Z motor has a brake. My plan was to support it with a car jack, and then disconnect the Z axis motor, then lower the head with the jack.
    My other thought was, if someone could tell me the voltage of the brake, I could apply that voltage to the cable to disengage the brake and then lower the head with the jack.
    Any other thoughts on a safe way to lower the head?
    Thanks!
    Mike
    15362
    Thanks!
    Mike
    You could connect 24v for the Brake but you would have to get the right wires connected or you could damage the encoder which is 5v max if you selected the wrong cable, so the best would be to remove the servo motor put a piece of wood 6x2 on the table and lower the head down it may lower by itself so be prepared
    There are 2 Brake voltages 90vDc and 24v Dc most you will find at 24v the brake wiring is in the main Power supply cable the encoder cable is a small diameter cable and a lot more wirers here is what the motor plug will look like
    Mactec54
    Apr 2008
    61
    Thank you Mactec54!
    Apr 2008
    61
    I'm going to have to go without using the Yaskawa motors. I found the drives don't work with step and direction signals, and I'm not smart enough to use Linux CNC. I'm only experienced with Mach3 and Centroid Acorn. So I'll either go steppers or DMM servos.
  1. Taig CNC mill basket case
    By betteron2wheels in forum Taig Mills / Lathes
    Last Post: 04-06-2019, 02:44 AM
  2. My light machines basket case....help?
    By johnny t in forum Benchtop Machines
    Last Post: 09-15-2015, 12:15 AM
  3. Just bought a used Desktop Mini Mill
    By bhux in forum Machinery Manuals / Brochures
    Last Post: 03-13-2015, 05:11 PM
  4. My Sieg X1 basket case
    By phansen39 in forum Benchtop Machines
    Last Post: 07-02-2013, 02:36 AM
  5. Mini-Mill Power supply case
    By hargray2 in forum Benchtop Machines
    Last Post: 01-24-2006, 06:44 PM
