586,055 active members*
4,324 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Identification of Old Router
    Apr 2010
    21
    A friend has acquired a very well made router with steppers from the 90's.
    No manual or operating instructions.
    Used in a production environment to engrave laminated plastic labels.
    Out of use for more than 15 years.
    Brand appears to be JIACHEN (will get country of origin on next visit).
    Has 3.5 " floppy.
    When turned on, computer comes up with DOS 6.2 and steppers move.
    Machine goes to home position and LCD display shows X, Y, Z at 0.00.
    An executable, "Ojet.exe", may be the machine operation application.
    Only problem identified is no-response from some of the membrane keys.
    Reverse-engineering will replace membrane with push button matrix.
    Can anyone help with accessing a handbook and operating instructions ?
    Can anyone shed some light on the code shown in the attached image ?
    This is the first few lines of "Square.PLT".
    John (in bush fire ravaged Sydney)
    Apr 2005
    304
    Re: Identification of Old Router
    The code is classic plotter file.
    PU ... Pen Up ...
    PA .. Plot Absolute ...
    Code interpreter is, I guess, in controller built in router.
    If I were you, I would check what kind of stepper motors/drivers are there and use the as starting point for conversion to modern system.
    Eg. external motion controller, G540 stepper driver, ...
    Give more details on stepper drivers....
    PS, keep wet
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. Pet Identification (Pet Tag) Engraver to buy
    By ryanb4614 in forum Want To Buy...Need help!
    Last Post: 06-13-2020, 11:10 AM
  2. rotary identification
    By hercules in forum Haas Mills
    Last Post: 12-01-2010, 02:59 AM
  3. Help with Identification - Compumotor
    By mattgatten in forum Servo Motors / Drives
    Last Post: 06-10-2010, 05:49 PM
  4. CNC identification
    By 777string in forum Benchtop Machines
    Last Post: 01-30-2010, 02:54 PM
  5. Tap Collet Identification Help
    By keebler303 in forum MetalWork Discussion
    Last Post: 12-18-2007, 12:09 AM
