586,317 active members*
3,421 visitors online*
    May 2016
    32
    Size of grease fittings on Fineline Routers
    Hi Guys.
    I need to get a new grease fitting for the right z-axis truck.
    They are chrome colored and have a right angle bend.
    The same fittings are used throughout the machine.
    Are they M4 or M6?
    If they are M6 I will order these ones from Avid CNC:
    M6 Flush Mount Grease Fitting | Avid CNC | CNC Router Parts
    Any help would be appreciated!
    Thank you.
    David
    Aug 2018
    621
    Re: Size of grease fittings on Fineline Routers
    Quote Originally Posted by Redcedar View Post
    Hi Guys.
    Are they M4 or M6?
    Thank you.
    David
    No idea but I would put some calipers on one and Google the size. The machines have changed a few times and who knows if all the zerk fittings are the same.
    Sep 2005
    1740
    My early 2018 (May) just used standard off the shelf grease fittings. They are not expensive, just go purchase a couple and see if they fit. I think I paid like $4 for a package of 6 or so. !/4-28 is one US size and I am sure the metric sizes are pretty common also. If you have some Digital calipers use them of course.
  1. Hiwin HG20 grease fittings???
    By moparx12 in forum Linear and Rotary Motion
    Last Post: 04-03-2018, 12:25 PM
  2. Grease fittings?
    By Spotswood in forum Avid CNC
    Last Post: 01-08-2018, 01:36 AM
  3. Replies: 6
    Last Post: 06-01-2012, 03:30 PM
  4. THK HSR grease fittings?
    By turboedgs in forum Linear and Rotary Motion
    Last Post: 11-29-2010, 04:29 PM
  5. Hiwin Rails/Grease fittings/lubrication?
    By CyborgCNC in forum Linear and Rotary Motion
    Last Post: 09-04-2009, 07:51 AM
