586,588 active members*
2,678 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > New angular bearings on my X2 made the spidle stiffer.. How to overcome it?
Results 1 to 19 of 19
    Mar 2016
    68
    Hi!
    I had just replaced both the stock bearings of my SIEG X2 Mill (MT3) to angular contact ones (rubber shielded), FAG 7206-B-2RS, using some guides, like Little Machine shop guide: https://littlemachineshop.com/images...ndle%20Kit.pdf and some guides with pictures like this one: https://www.arceurotrade.co.uk/revie...58_X2_Mill.pdf.
    It all went well, I also trammed the spindle head to the back part of the head for left/right and tilt adustments.
    I think the spindle, although having no play at all, and no runout apparently, seems a little bit stiffer than before.
    I don't even need to adjust the left hand nut on the top of the spidle, as the method for inserting the two bearings already left it with no play at all.
    I have a belt drive conversion kit installed also, and removed all the gears inside, even the spindle one.
    I had the belt drive conversion kit modded (added two more pulleys in motor and spindle's original kit's pulleys) to allow also 10.000 RPM, just for engraving. It will be hardly used.
    I think the spindle wiith new bearings, although perfectly aligned, seems stiffer, although not much more than before, and the spindle case gets hotter than before, the higher the speed it runs. At 4600 RPM in 10 minutes it gets to 60 degrees celsius, both the spindle housing, and even the pulleys attached to the spindle.
    I connected a multimeter directly to measure the motor output draw (its rated for 220V - 2.2A)
    With the 600 RPM pulley the motor draws IN IDLE (not endmills attached) at max speed, close to 0.6A
    With the 4600 RPM pulley it draws in idle also almost at max speed too, close to 1.3A
    But with the 10000 RPM pulley it draws almost 2.8A, at 7000RPM, in dle. If I go higher than this the controller stops the motor, for protection. With this high speed pulley the speed has to be reaaaaaaly slowly increased to the point of being useless practically.
    Also it's only being tested in idle, not endmills attached. If I try to turn on the spindle and increase the speed a little bit faster, the current draw increases and the controller stops the motor.
    So I have some doubts:
    Are this Angular Contact bearings really stiffer than the Chinese stock ones, to the point of making the motor work harder than before (draw more current and heat more), when it had the original bearings?
    Will the new bearings (bearings/spindle assembly I mean) , with use, become less stiffer than now, as they're new? Is there a procedure to make it happen, to make it... soften... like run at some speed for some minutes, let it cool down, do it again?
    When I installed the bearings following the instructions on the LMS kit, could I have put too much preload when seating the bearings/spindle? If so, is there a way to undo it a little bit, without damaging the bearings? I'm not even using the top nut over the spindle top.
    Will it be possible/practical to use the higher speed pulleys - 10000RPM - just for engraving, or these bearings aren't meant, or can't handle this speed?
    Thanks for reading!
    Regards, Rodrigo
    Dec 2005
    436
    Re: New angular bearings on my X2 made the spidle stiffer.. How to overcome it?
    I do not have a definitive answer for you but can share my experience.
    I installed Japanese angular contact bearings. They did not have shields. I can run the spindle for 3 hours and everything stays almost at room temperature. I do not think the shields on the bearings would make the temperature rise so much.
    Without the motor or pulley attached, my spindle rotates easily. If I spin it by hand as fast as I can, it continues only for 1 or 2 revolutions.
    The temperature rise you describe seems too much to me.
    So my opinion is that you have a problem that needs to be fixed.
    I would suggest three things. 1: disassemble the spindle and verify that the angular contact bearings are installed properly. Usually there is an indication, an arrow, to tell you which way to install it. 2: make sure both bearing are smooth when you turn them in your hand. If they run rough in your hands they are no good. But if they run smooth in your hand it is still possible they will run rough in the machine. 3: when you re-install everything make sure that you do not compress the bearings too much, the left hand nut is only loosly installed. so even before you install the left hand nut, make sure the bearings are not overly compressed.
    Mar 2016
    68
    Quote Originally Posted by cncuser1 View Post
    In my setup, without the V pulley attached, if I rotate by hand my spindle gives 1/3 of a spin only.
    Before installing the AC bearings, both bearings seemed smooth but didn't spin easily. Also, as they are Angular contact, the center of them wobbles before the spindle is inserted into them, So I coudn't test for a spin before installing them. The bearings made no noise, and after installation, they still run silent, no strange noises, no roughness on them, at least to my ears. The spindle runs silent.
    When I installed them, i noticed that they didn't slip easily through the spindle. They had a really tight fit on the spindle
    Is it possible to remove the AC bearings without destroying them? I read somewhere it's not possible. I used those instructions of Little Machine Shop for removal of the stock ones and installation of the new ones. Can I use the same procedure to remove them?
    Thanks for the help!
    Dec 2005
    436
    The comment about belt tention is a good one, it should be investigated
    Quote Originally Posted by Rimbaldo View Post
    ....what is the part number for the bearings, do you have a link to the technical specifications.
    Your comment about wobbles....my bearings didn't wobble
    Mar 2016
    68
    Sorry, English is not my first language. By “wobble” I meant that before installing the bearings in the spindle, the inner race had some small...movement... play...to any direction and if I remember, up and down also, in relation to the outer race. Different from the stock bearings, in which the inner race rotates perfectly centered around the outer ring. And doesn’t move to anywhere besides rotating.
    After installation there’s no play, no weird sounds, no “wobble”
    The bearings are FAG 7206B-2RS-TVP. You can check them in this link:
    https://www.bearing-king.co.uk/bearing/7206-b-2rs-tvp-fag-x-life-sealed-angular-contact-bearing-30x62x16mm/24338
    I installed them both with the thicker part of the inner races facing the outside of the spindle head case.
    My runout is less than 0.01mm. Is this good at least?
    Also, I notice heat only when running at 4000rpm or more. If I use the low speed pulley, that reaches 1600 RPMs, the head and motor and spindle remains at 30 degress celsius.
    Dec 2005
    436
    I run my spindle at about 4K rpm max , so our temperatures are similar.
    I think I understand what your description of the "wobble". I am not an expert but I do not remember my bearing having this.
    Also I am pretty sure I only installed one AC bearing in the spindle, near the cutter. The bearing near the pulley was a normal bearing. I will look later. You must be very sure the bearing was installed with the contact angle facing the correct direction.
    I will look later about how the bearings should be installed.
    15362
    https://www.bearing-king.co.uk/beari...x62x16mm/24338
    You have Ac Bearing by that part number 40 degree which is higher than normal for these spindle bearing, but won't cause any problem just can take a higher loading, the press fit may be to tight for the grade of bearing you are using this will cause over heating for removing yes you could damage them if they are too tight on the spindle shaft
    So the fit on the shaft is very important
    You can also remove the inner seals this can reduce the friction but you also can loose the grease in the top Bearing also by doing this
    The normal mounting for spindle Bearings like this is called Back to Back so you may have them mounted Face to Face which still will work but not as good as Back to Back this snip may help
    Mactec54
    Nov 2004
    239
    Do you have the part number for the bearings you installed?
    Dec 2005
    436
    Shanghyd: I orded one of each
    https://www.bearingscanada.com/Produ...7007CP5-ABEC-5
    https://www.bearingscanada.com/Produ...tCode=7206C-P5
    I made a mistake in my previous post, both are angular contact.
    Jan 2013
    630
    If you are generating heat with no cutting load then you have too much preload on the bearings or the side loading of the belt drive is inducing too much load. Are you running timing pulleys or V pulleys? A timing pulley doesn't need as much tension on the belt as a V pulley.
    Mar 2016
    68
    Quote Originally Posted by Kenny Duval View Post
    Hi Kenny!
    I'm using V pulleys, with not to much tension. They're quite thin actually.
    Using the instructions of Little Machine shop for assembly/disassembly of the bearings, I don't know how to put or not preload during installation.
    The reason is that the lower bearing is first installed inside the spindle until it is seated the lower step of the spindle. Then the spindle/lower bearing assembly is pulled upwards with a system (pipe) that pushes the upper bearing down untill it's fully seated, as the lower one is being pushed upwards. So both bearings are pushed to their seats at the same time. So by using this method I can't individually install the bearings. Is there another way of installing the bearings/spindle?
    I know the fit of the spindle inside the bearings is really tight. It's impossible to put the spindle inside the bearings by hand.
    Thanks for your help!
    Jan 2013
    630
    Heat only comes from friction and that is created by either squeezing the AC bearing together too much, misalignment of something in the stack or lots of side load introduced either by cutting forces or some other mechanism such as the belt tension on the belt drive. If the belt isn't a banjo string then I'd be looking at taking the spindle apart again and rechecking everything. There is no way turning the spindle alone should ever get the machine to shutdown if everything is fit together well.
    Mar 2015
    410
    When ever you change bearings, you have to run them for a while (5 min) at low RPM without load. Than gradually increase the RPM a bit and again let it run a while. Repeat this procedure until you run at max rpm. The whole process will take about half an hour. Doing so will gradually warmup the bearing, and this will spread the lubrication in the bearing.
    Contact angle bearings will generate more heat then ball bearings under the same conditions and tapered bearings will generate even more heat.
    You must not exceed the maximum speed the bearings are specified.
    If after running in, under no load, not exceeding the bearings max RPM, the bearings get hot (can't hold them for a while meas ++50°), the preload is to much.
    Your original bearings where ball bearings and they where pressed fit. Your contact angle bearing, at the side of the preload nut, needs to move "freely"on the axis to set the preload. Because the axis was made for press fit (it is to thick), the contact angle bearing can't move freely. It is (strongly) pressed on the axis and probably with to much preload. This is a common problem when replacing ball bearings by contact angle bearings and very difficult to avoid.
    There is not a good fix for this but in time (a few hours of use under load) the problem will get less due to the "running in" of the bearing.
    Machine setups using contact angel bearings are stiffer than ball bearings due to the preload. The preload also eliminates the play as long as the load on the bearing is less than the preload. Using more preload than the actual maximum load will not improve the machined part, just increase the wear.
    Even knowing all this, I also had to much preload when I replaced the ball bearings by contact angle bearing on my mini lathe. For what it is worth, I can't say the turning results are improved. Maybe this is because the turning results where already OK or the old ball bearings where still good.
    Mar 2016
    68
    Quote Originally Posted by hfjbuis View Post
    Thanks a lot! Really good explanation. I guess I’ll use the mill for some time to check if the spindle/bearings get better with time.. won’t try to remove and re-install the bearings right now!
    Mar 2015
    410
    Removing and reinstalling probably won't fix the problem and there is a high risk you damage the bearing.
    I guess the the replacement bearings the mill manufacturer sells, are designed as replacement and have a slightly larger bore diameter.
    Look at this chart for more information https://www.skf.com/binary/21-292339..._12-292339.png
  1. FAG vs. No-Name Angular Contact Bearings
    By JukeBox in forum Linear and Rotary Motion
    Last Post: 01-01-2016, 06:59 PM
  2. Angular Contact Bearings
    By Anita in forum Linear and Rotary Motion
    Last Post: 10-28-2012, 03:17 PM
  3. How To Properly Use Angular Bearings
    By 2_many_hobbies in forum Benchtop Machines
    Last Post: 06-10-2009, 05:04 AM
  4. why angular contact bearings for X3?
    By lagfish in forum Benchtop Machines
    Last Post: 01-09-2008, 12:12 AM
  5. Angular Bearings in a RF 45
    By fc911c in forum Benchtop Machines
    Last Post: 01-14-2007, 11:59 PM
