586,071 active members*
4,005 visitors online*
    May 2004
    22
    water spindle
    I got a cnc router with water spindle, the water has a lot of rust and oter things in, the spindle can be turned by hand it is not locked up. What is the best way to clean it and flush it out. Thanks Dan
    1227
    Re: water spindle
    Don't plumbers use something for flushing crud from radiators?You might start by calling a tame plumber but be cautious about sending electricity through until you are sure the cooling circuit hasn't corroded to the point where it might allow water to pass through and short the motor-or worse.
  1. Which water mixture to use for water cooled spindle ...
    By evalon in forum DIY CNC Router Table Machines
    Last Post: 05-15-2019, 02:44 PM
  2. Replies: 2
    Last Post: 03-16-2017, 02:16 PM
  3. Replies: 1
    Last Post: 12-01-2016, 05:34 PM
  4. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  5. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
