586,121 active members*
3,624 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > U100L - C axis Zero
Results 1 to 3 of 3
    Nov 2015
    17
    U100L - C axis Zero
    Hi!
    Where is the parameter for setting the C zero Axis in U100L control?
    I check and check but i don't look anything
    In system parameter i have X, Z, M, T, but not C
    And i try to change optional parameter but change only "CD" parameter so change the M19 parameter
    But not the C zero axis... any solution?
    Thank you so much
    Apr 2009
    1262
    Re: U100L - C axis Zero
    You are missing the obvious one. It is not in parameter mode it is in zero set mode. Each axis including C will have a Zero Set.
    Best regards,
    Jun 2015
    4154
    hy, are you looking for program zero, or for encoder zero ?
    ... program zero can be edited for : xzc
    ... encoder zero : all_above + mts
    please, describe a bit more what you wish to do
    if you are looking for encoder zero, then try syspara2, but i am afraid that this menu is not on your machine, so maybe all you need is screen-extend inside the menu where you set program zero / kindly
  1. OSP U100L
    By fomaz in forum Okuma
    Last Post: 02-09-2024, 09:10 PM
  2. Okuma LB300///OSP U100L
    By iffe123 in forum Okuma
    Last Post: 08-25-2023, 04:30 PM
  3. OSP -U100L
    By CNCPro26 in forum Okuma
    Last Post: 04-11-2017, 12:25 AM
  4. Run from line U100L
    Last Post: 09-07-2014, 10:20 PM
  5. Replies: 1
    Last Post: 01-14-2011, 01:20 AM
