586,441 active members*
4,093 visitors online*
Results 1 to 9 of 9
    Jul 2017
    57
    Misaligned somehow
    I have a machine with similar dimensions and electronics to CNC router parts machines, but I’ve been experiencing a major alignment issue of some sort and I can’t figure it out. While doing an engraving of a frame I see that 2 opposite corners of the frame are way off from parallel with each other. Can someone tell me the likely adjustment I need? I will post a photo to illustrate what I mean.
    Attached Thumbnails Attached Thumbnails B22F8072-C021-44FE-84D0-D64408034295.jpg
    Re: Misaligned somehow
    That's likely to be a mechanical issue. I'd go through the machine and make sure that nothing is loose.
    Jul 2017
    57
    I just checked the table and the distance across the corners are off. I’m not sure how I’m going to get them square, but hopefully I’ll be able to. There may be a mechanical issue as well, but I think what is causing those 2 corners to distort that significantly is that the table isn’t square.
    Mar 2017
    250
    Do you have a homing sensor on the left and right front of your table? The cncrp machine does and uses it to get the racking out. They are screw adjusted and make it simple to align. They have the alignment and tramming video on their YouTube.
    Sent from my SM-N960U using Tapatalk
    Jul 2017
    57
    I only have it on the left side. I use switches rather than sensors. Would that work? I realized after checking the table that the distance between opposite corners was not the same, indicating that the corners weren’t exactly square. I’m going to try to see if I can loosen the fasteners enough to straighten it up. I’m a little skeptical that I will be able to but I’m going to try. If that’s unsuccessful, I may have to recut the beams or fasten them using just the aluminum plates rather than the beams themselves.
    Feb 2005
    829
    Your problem is not with alignment of the machine or axis. Something is causing your cutter to shift while cutting those particular lines while running. There is no alignment issue that can cause two different cuts in the same axis to be shift during the same gcode operation.
    You need to check your motion hardware for loose set screws, belts, springs, etc depending on how your machine motion system works.
    More pictures of these systems would assist us with helping you troubleshoot this issue.
    Jul 2017
    57
    Okay. I appreciate the explanation. That makes sense.
    Dec 2006
    86
    What happens when you run the program again over the same path?
    Same cut, no cutting load. Would show machine flex issues.
    May 2018
    85
    That’s an odd problem indeed. You have several other lines in the same axis that cut OK, what is different about the two that went crooked?
    Checking your frame for square was a smart place to start, sometimes even the pros overlook the obvious. My big yellow router had an issue from the factory where it would cut parts .030” wider on the right half of the table. Left side cut dead-nuts. Loooong story short, the guide rail datum on the gantry was curved by about .010”. So the spindle was swinging ever so slightly like a pendulum. Took them over a year to diagnose and repair.
  1. ATC misaligned
    By brokenrinker in forum Fanuc
    Last Post: 11-21-2012, 03:09 AM
  2. Agie UV misaligned
    By rftools in forum EDM Discussion General Topics
    Last Post: 04-14-2011, 08:44 PM
  3. How to calibrate misaligned axis - Urgent!
    By Grant Nicholson in forum Techno CNC
    Last Post: 07-01-2010, 07:23 PM
  4. G251 Misaligned components?
    By Adamj12b in forum Gecko Drives
    Last Post: 09-16-2008, 03:08 PM
