586,067 active members*
5,288 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Fiber Laser Cutting Topics > 6000W fiber laser cutting machine - max. cutting thickness 30mm (MS)
Results 1 to 1 of 1
    Dec 2019
    Here is the reference for material to be cut and the max. thickness, so that you can easily choose the laser power for your fiber laser cutting machine.
    Cutting Materials and Thickness
    Materials Auxiliary Gas Maximum Cutting Thickness
    Carbon Steel O2 12mm 14mm 18mm 20mm 22mm 30mm
    Stainless Steel N2 5mm 6mm 8mm 12mm 14mm 25mm
    Aluminum N2 3mm 5mm 8mm 12mm 16mm 25mm
    Copper N2 3mm 5mm 6mm 8mm 10mm 14mm
    Laser generator 1000W 1500W 2000W 3000W 4000W 6000W
    please feel free to drop a line to jack(at)hongniulaser.com
