586,036 active members*
3,828 visitors online*
Results 1 to 12 of 12
    Aug 2007
    224
    Interpretation problem
    Please some one guide me how to interpret this drawing call off.. please check attached JPEG
    Regards
    Fss
    Dec 2008
    3109
    Re: Interpretation problem
    top face (A) must be flat within 0.5mm
    ..... same with opposite face but opp. face must also be parallel to A within 0.02mm.... and thickness must end up to be between 32.10/32.00mm
    3.2mu surface finish is a little coarse but should be easily achieved
    Aug 2009
    1573
    Aug 2007
    224
    Quote Originally Posted by Superman View Post
    Thanks superman for reply..I am confused between 32+0.1mm and parallelism 0.02 with respect to datum A.and flatness..don't you think these callout conflict each other... need assistance....
    Dec 2008
    3109
    Quote Originally Posted by fsa View Post
    It would seem that there is conflicting GD&T controls
    .... but it basically needs both faces to be very parallel AND the 32.1/32.0 size maintained ( just to put it into easy language )
    There is a lot more to what is implied in the dwg
    ... the 0.5 flatness allows a bit of wave form the machining of either face, or even a little bit of slope
    ... the 0.02 parallelism controls the wave/slope to be in-sync to each other
    ... the controlled thickness - obviously to fit a defined gap ( measured across faces using a micrometer )
    (how's that for a breakdown explanation)
    Aug 2007
    224
    sir you are right..but my concern is flatness 0.5mm on both faces and parallelism 0.02 with respect to Datum A..they both are conflicting each other ..if i maintain flatness 0.1mm on one face and 0.2mm on other face,,then the parallelism 0.02mm is automatically out of range..am i right ???
    Sep 2017
    37
    The datum face for the parallelism is the opposite face of the part. Therefore the smaller parallel tolerance could be maintained if the part faces were out-of-flat in the same direction. Sort of as if the part was a bent sheet.
    Dec 2008
    3109
    I do agree that the opp. face flatness is a redundant control as the parallelism & size is dictated by the A datum face machining
    ..... a sheet was a good example of the tolerance usage... the waviness cannot exceed 0.5mm over the face extents
    Aug 2007
    224
    still some questions please check jpeg for details
    Dec 2008
    3109
    IMO... flatness (when measured in free state) is less than 0.5mm TIR by dial... pass (or a feeler gauge check underneath)
    ... parallelism of one side to another... equal to or less than 0.02mm... pass (on maximum)
    ... thickness... size within tolerance... pass (on minimum)
    You've done well for a 300x200 piece... hope you only need to do one.
    ( looks a real pr!ck of a job )
    Aug 2007
    224
    oh really superman you mean my measuring method is right ..also just for confirmation that on different points when i measure from micrometer is actually measure parallelism...am i right???...i have to make 3000 parts a months..this is aluminium casting parts ..i have to machine just 2 faces as as per drawing.. also experience the material deformation or twisting after machining ...which is the cause of more then 0.09mm value if i check my part under dail tip ..my dail setup is fixed and i move the part along part profile ....
    regards
    fsa
    May 2020
    Doesn’t it bother you that the sketch was not drawn according to the rules?
  1. Print interpretation
    By CFS in forum German
    Last Post: 04-04-2010, 10:28 PM
  2. g code interpretation needed
    By 15mgtar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-21-2010, 03:02 PM
  3. 0M Macros - Interpretation
    By Zoner in forum Fanuc
    Last Post: 12-11-2009, 03:10 AM
