586,069 active members*
3,363 visitors online*
    May 2009
    Tormach 1100 Random Z issue
    Hello, I have had a parallel toolpath on the mill for about 14 hours, I've come to check on it and seen this low spot, and basically want to know what the most likely cause of this is. Gib perhaps?
    its the only one on the whole part, and it stops as the path sinks into the cavity.
    Any ideas?
    Jun 2014
    1780
    Re: Tormach 1100 Random Z issue
    Usually if there is an anomally and it corrects itself it is not due to a machine problem, usually when that happens its software related.
    Just a guess.................
    I used to run into problems like this with Mach 3 but usually that didnt correct itself. Pathpilot has never had a miscue here.
    mike sr
    Oct 2005
    21
    Do you have an automatic oiler? It could be the hydraulic force of the oiler pushing the saddle and table up during oiling, thus the cutter cutting deeper on one or two passes only.
    May 2009
    Quote Originally Posted by 79rallysport View Post
    Yes we do have an auto oilier on it. Looks like the pressure of the auto oilier lifts the table by over 0.001" on the dial indicator.
    Problem solved. Thanks for the help.
  1. F360 - Tormach PCNC 1100 Post Issue on Drilling
    By smokediver576 in forum Autodesk Post Processors
    Last Post: 08-27-2017, 11:29 PM
  2. Tormach 1100 S3 using Tormach 1.5" face mill....
    By dneisler in forum Tormach Personal CNC Mill
    Last Post: 05-06-2015, 04:50 AM
  3. Tormach 1100 Passive Probe Calibration Issue.
    Last Post: 01-29-2015, 03:46 AM
  4. New Tormach 1100 series 3 vs. Old Tormach 1100 series 1 to purchase
    By inventor1227 in forum Tormach Personal CNC Mill
    Last Post: 03-21-2012, 09:55 PM
  5. 2d random toolpath issue
    By rich_cree in forum Vectric
    Last Post: 07-24-2009, 12:35 AM
