I'm sorry if this has been answered before (I used the search but didn't turn up anything). I purchased a couple of MCG ID33004 servos and while the MCG pdf file on this servo led me to believe that there was a 0.25" diameter rear shaft, they showed up without a rear shaft for the encoder. My question is how would the company add the rear shaft? I have seen the website where the guy drilled a hole and superglued a shaft in, but my question is how would MCG add the rear shaft? Would it be a steel shaft that is knurled and pressed in? Or would it be tapped and threaded in with locktight? Or other? I thank you for your response!
