586,067 active members*
5,346 visitors online*
    Jun 2018
    Amada FBD 8025 battery
    Hi. I get alarm on screen. It says (loss of battery charge for memory back up). where I can find that old battery so I can chance it to new one.? Monitor is NC9-F If that matters. Machine is build 1989 and I think theres still original battery.
    Mar 2009
    101
    Re: Amada FBD 8025 battery
    Quote Originally Posted by Henkkali View Post
    Did you resolve issue? That control is not supported. Battery maybe on MC 061 board. Any time you are looking for help on that machine make sure you tell them it is F control makes a big diff.
    May 2020
    thanks for taking the time to explain.
    8 ball pool
    Feb 2021
    5
    You will have to disassemble the control panel. Under the monitor, under one small board. There is also a memory card and battery.
    I'm looking for an electronic version of the management to translate it.
    Feb 2021
    5
    Hello !
    I am from Bulgaria. I recently bought an old AMADA HFBO 8025-1996.
    I'm looking for a file instruction. I want to translate it.
  1. Replies: 2
    Last Post: 04-23-2022, 04:55 AM
  2. 2100 NCK ALARM 810D - NEED TO CHANGE BATTERY - WHERE IS THE BATTERY LOCATED?
    By scottbryce in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-22-2021, 07:35 AM
  3. Best quality lithium carbonate battery grade supplier and battery grade dealer
    By elitechbio in forum Uncategorised CAM Discussion
    Last Post: 12-12-2018, 09:12 AM
  4. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  5. Replies: 2
    Last Post: 11-07-2013, 04:34 AM
