586,076 active members*
3,779 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Backplate adapter for 4" chuck
    Apr 2011
    131
    My cnc lathe was originally equipped with a 4" chuck and a separate 2-1/4"-8 threaded backplate adapter.
    Unfortunately the chuck was missing when I got the lathe so I need to purchase a replacement.
    My question is whether I need to machine my own backplate adapter using something like this (I can't find one specific to a 4", this is smallest I've found) https://littlemachineshop.com/produc...ProductID=1923
    Or whether I will get sufficient accuracy with a pre made one such as this (https://allindustrial.com/all-indust...-lathe-chucks/) which seems to match the chuck I'm looking at.
    If anyone knows of alternatives I'd love to get a URL.
    Sent from my MI PAD 4 PLUS using Tapatalk
    Nov 2009
    4415
    Re: Backplate adapter for 4" chuck
    Both routes would be ok depending on your skill level. I would think you could skim cut the prebuilt one on your lathe to correct most issues.
    A lazy man does it twice.
    Apr 2011
    131
    Quote Originally Posted by Fastest1 View Post
    That's what I was hoping. The prebuilt is cheaper and I have so many projects already that I'm looking to simply things.
    Nov 2009
    4415
    There is no shame in getting it done quickly ;-)
    Mar 2017
    411
    Go with the finished one. Either way, you should install it and then check the runout and concentricity. If it isn't perfect give it a skim cut as fastest1 said. You should also then check the runout of the chuck after it is on the plate and true it up.
  1. 5C COLLET CHUCK ADAPTER
    By BIGBLOCK1965 in forum Shopmaster/Shoptask
    Last Post: 09-13-2016, 02:15 PM
  2. A1-6 to D1-6 Lathe Chuck Adapter
    By TonyW in forum Uncategorised MetalWorking Machines
    Last Post: 08-19-2012, 04:59 PM
  3. chuck adapter question
    By neurofen in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2011, 06:58 PM
  4. MT3 Chuck adapter removal
    By whitehedr in forum Benchtop Machines
    Last Post: 12-14-2009, 08:22 PM
  5. New 6 Jaw Buck Chuck Backplate
    By Woodenspoke in forum MetalWork Discussion
    Last Post: 01-21-2007, 09:22 PM
