586,043 active members*
3,782 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas MiniMill door interlock failure
Results 1 to 10 of 10
    Nov 2019
    4
    New here, just bought a 2000 MiniMill for use in a home shop.
    One of the issues I ran into is an issue with the door interlock circuit. The control reports door open even though the circuit is good all the way to the IO board (so the switch itself and wire seem good). I can run the machine by using the door override setting (51) but have to do that each power-up.
    I am an EE with computer design experience, scopes, etc. Does anyone know where I can find the schematic for the IO board?
    Side issue: There are no o9xxx programs on the machine (specifically the QC file, 09999, and the spindle warmup routine, etc.). I suspect someone accidently cleared these when clearing the machine when they sold it. Is there a place I can get a copy of all the o9xxx programs I should have?
    BTW: Anyone else in/neat Tampa operating a MiniMill?
    Regards,
    Chuck Hackett
    Tampa, Florida
    Mar 2008
    683
    Re: Haas MiniMill door interlock failure
    I've been doing the same thing for years. I have yet to find a fix.
    Aug 2009
    1573
    Quote Originally Posted by ChuckHackett View Post
    I'm not a Haas guy but, Fadal 88HS had Service Programs stored on an EPROM that could be loaded into Part Program memory. They used O5xxx numbers. Haas must have some Code to Load them. Fadal is a simple TA,5 at the Command line.
    added....found this in the manual for Haas "23 9xxx PROGS EDIT LOCK This is an On/Off setting. When it is off, the machine operates normally. When it is on, the 9000 series programs (usually macro programs) are invisible to the operator and cannot be uploaded or download. They also cannot be listed, edited, or deleted"
    https://www.haascnc.com/content/dam/...ent---2003.pdf page 269 Parameters
    15362
    Regards,
    Chuck Hackett
    Tampa, Florida
    If there is not thumb drive in the cabinet then you could get the missing files from Haas, they will just need the machine number and they will tell you everything about that machine
    You have to cycle the door before power up I have the switch made all the time so has never been a problem door open or closed, but will have to open and close it before power up
    Mactec54
    Nov 2019
    4
    Quote Originally Posted by machinehop5 View Post
    Yup, I have that setting on so I should be able to see 9xxx progs.
    One of the progs not there was the "Quick Code" (not "Visual Quick Code") prog (9999). I got a copy of that from the local dealer but have not put it in yet.
    Nov 2019
    4
    "get the missing files from Haas" -> Who would I contact, the local office? and what exactly do I ask for? "Programs shipped with this machine", "Programs compatible with this machine"?
    I looked on the HaasCNC website but I did not see anything like "Resources" under support, etc. that looked like a library of programs (utilities) one could download. Is there such a resource on the web?
    "before power up" ??? how would open/close the door before power up make a difference? Do you mean before pressing "Power-Up Reset"?
    15362
    Yes it is a requirement the machine needs before it will power up ( Power-UP Reset ) Door must be Opened / Closed It will tell you this on screen if you have not done it
    For the files no there will not be anywhere to down load them from, but if you call Haas customer service or your local ( HFO ) with your machine number they will tell you what your control should from have giving them the serial #
    To load missing files if you don't have them call you local Haas repair ( HFO ) they may be able to help you over the phone or do a service call
    https://hfophillips.com/details/pagedetails/training-us
    Mactec54
    Aug 2009
    1573
    You mean Setting 23 is OFF....right?
    927
    Here is warn up program. (O12020 Below)
    Also a shot of the IO board. I just unplugged the door switch from P8. And jumped it as shown with common computer jumper.
    This is on a 2000 mini mill. serial #21xxx
    I don't remember having to do anything else. Like setting or parameters. But it has been 19 years since I installed it..
    I have never had to open/close door before powering on. On any of my Haas'. But not saying that you don't, just never seen it with mine.
    Hope this helps.
    15362
    Quote Originally Posted by wms View Post
    Hope this helps.
    It's a built in safety feature you must of by passed it, or the machines that old may not of had it
    Mactec54
  1. Door interlock?
    By Edster in forum Fadal
    Last Post: 07-12-2014, 06:40 PM
  2. Door Interlock
    By akhilb in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-16-2011, 10:46 PM
  3. DOOR INTERLOCK
    By gtrrpa in forum Mori Seiki lathes
    Last Post: 04-18-2011, 07:56 PM
  4. Please help-door interlock
    By em322 in forum Okuma
    Last Post: 01-19-2010, 09:54 PM
  5. Door Interlock
    By hatchmar in forum Fanuc
    Last Post: 12-30-2007, 01:52 AM
