586,609 active members*
3,492 visitors online*
    Jun 2007
    6
    Is my drawing ok? *file now attached*
    I am hoping someone could e-mail me at [email protected] so I can send a drawing a friend has made for me. I am worried b/c he couldn't draw curver well so instead he amde he curves a little angualr so the CNC shop could take the outer points and make the proper curves. It is also in 2D. I'm just looking for an ok from someone that these drawings would be ok to send to a manufacturer.
    Jun 2007
    6
    here is the drawing
    Attached Files Attached Files
    Jun 2003
    2103
    If I were going to be your manufacturer I would want dimensions on the drawing. For instance. The drawing template says the the scale is 2:1, but I imported it into Rhino, and the overall length of the body measure right around 18", which is about right for an electric body. Were does the 2:1 come into play?
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Jun 2007
    6
    Thanks for the reply Mike! I will have my friend add the dimension, will the body come out smooth instead of angular?
    E-mail sent!
    May 2005
    1810
    Your drawing looks fine. It would process just fine. Any fine faucets could be blended out by hand.
    ***edit***
    I see your concern - there are a few jagged edges here and there. I am not sure if that's your concern, but if so, simply smooth them out or look at the attached file - I imported into CAD, Splined it and then DXF'd out in an older version, so the Spline became a polyline which will roll right through most CAM packages. See attachment.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
  1. Drawing help
    By brtlatjgt in forum Solidworks
    Last Post: 06-28-2007, 06:33 PM
  2. Drawing help
    By dwacker in forum Dolphin CAD/CAM
    Last Post: 05-08-2007, 09:53 PM
  3. Need drawing converted
    By seansear in forum Employment Opportunity
    Last Post: 01-27-2005, 04:00 PM
  4. Need drawing converted from .max to .3ds
    Last Post: 01-03-2005, 06:51 PM
  5. Drawing ?
    By Ken_Shea in forum OneCNC
    Last Post: 06-09-2003, 04:54 AM
