586,069 active members*
3,629 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Need help...estop activated hit (key) to clear
Results 1 to 7 of 7
    Jan 2020
    4
    Having trouble with my Bridgeport ex trak dx mill..it was working just fine had just got done milling a slot on a shaft and plunged a hole
    to start the next key way slot. Turned off mill and water to clear off all shavings and water locked mill back down in place pressed the start button and nothing..looked at cnc and said emergency stop activated hit (key) to clear...doesnt say what key to hit just says hit (key) and sometimes will come up with message saying spindle motor overload..so I've hit every key...checked my e stops..all my brake levers are loose...motor is free...all wires connected and working..oiled all oil points..checked breakers...reset breakers...e stop button not actually activated but somewhere its tripped and cant resume my very busy list of jobs
    Re: Need help...estop activated hit (key) to clear
    Control type (Fanuc)?
    Jan 2020
    4
    Quote Originally Posted by drdos View Post
    Not exactly sure
    Attached Thumbnails Attached Thumbnails 15784173476545474620048478726836.jpg
    Jan 2020
    4
    Quote Originally Posted by Kdub424 View Post
    Not exactly sure
    this is the manual came with but says nothing about my problems
    Attached Thumbnails Attached Thumbnails 15784175473098061220240731235860.jpg
    Not Fanuc, I have no experience with this controller.
    Aug 2009
    1573
    Check input power.. sounds like one leg of 3 Phase is low or not working. Converter problems?
    ......you might need a wiring diagram
    https://www.cnczone.com/forums/bridg...ak-wiring.html
    May 2016
    526
    Check your switches especially Z as that's where the normal problems occur
  1. Replies: 4
    Last Post: 06-16-2017, 01:21 PM
  2. Replies: 14
    Last Post: 05-04-2015, 02:21 PM
  3. activated carbon filters
    By jorgenk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-01-2012, 04:44 AM
  4. cann't clear estop alarm after 4th was removed
    By dingo0722 in forum Haas Mills
    Last Post: 04-06-2012, 08:44 PM
  5. Activated tools
    By motorfräser in forum Index and Traub
    Last Post: 02-08-2010, 05:40 PM
