586,119 active members*
3,510 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Axis configuration, please help.
    Feb 2007
    632
    Hi all,
    I have just cnc'ed my x2 mill for the x and Y axis. However, I am getting some problem with the way the coordinate of the table has been set up. Here is a picture to illustrate. Can anyone help me on how to set up the coordinate such that when I am standing in front of the mill, the left side of the table is -ve and the right side of the table is +ve. The Y axis is fine. Thanks.
    Alex
    Sorry here is the main question. Where in Mach3 can I reverse the direction of the x axis. I.e. If it goes to the left, it shows positive on the DRO and negative when it goes to the right. I hope you can understand what I am trying to say. At the moment, When I move the table to the left, it should show negative but its showing positive. Thanks.
    May 2006
    1469
    Alex
    You don't say what you are using to control your X2. This only applies if you are using Mach3
    Go to Config menu then Homing and Limits, select Reverse on the X axis.
    If not using Mach then I can't help software wise.
    Electrical connections can also be altered if needed.
    Greg
    Feb 2007
    632
    Hi greg,
    Thanks a million. I read tru my post again after seeing nine viewing and I knew I was missing the critical question. To answer, yes, I am using mach3 and I went through the config tab in mach3 many times and I didn't even see that. Thanks again. Its sorted.
    Alex
  1. Configuration Of Output Pins In Parallel Port FOR 4 AXIS
    By Khalid in forum Open Source Controller Boards
    Last Post: 05-20-2007, 07:55 AM
  2. Pin Configuration for minitech2
    By gone4pepsi in forum Mach Mill
    Last Post: 02-07-2007, 04:37 PM
  3. Need help with axis configuration
    By jetijs in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-24-2006, 11:06 AM
  4. configuration: SCALE
    By slp_prlzys in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-23-2006, 04:38 AM
