586,121 active members*
3,580 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Engraving with High Speed Spindle
Results 1 to 8 of 8
    Jun 2006
    3063
    This little logo was milled in acrylic with the Proxxon high-speed spindle on a Tormach mill using a 1/8" carbide engraving bit, 60° & 0.005" tip at 0.010" DOC, 10k rpm, and 6 ipm feed.
    I've got flood coolant but decided to just use a shop vac to continuously suck the chips from the cut for this job.
    Mike
    Feb 2006
    1072
    Looks great, Mike! What did you use to fill in the lines?
    Randy
    Nov 2005
    65
    Mike, what is that curious telescoping device? Could that be the manual ruled slide calculator that my granddad told me about?
    Feb 2006
    1072
    If it is, the C/D scales really need to be recalibrated. But I was going to let that [wait for it] slide.
    Best regards,
    Randy
    Jun 2006
    3063
    Randy,
    The logo was filled with EngravoColor from New Hermes. It's looks like a colored wax (much like a stiff crayon in texture) and worked pretty good considering the old tube I have is probably 20+ years old. I just rubbed it into the surface hard enough to fill the lines and then rubbed the excess off the top surface. I'm on the lookout for current replacements but haven't found much yet, probably I'm not sure what search terms to use.
    Edit: the sticks as well as some other interesting coloring chemicals/paints are available here:
    http://www.gravograph.com/usa/Engrav...s_Supplies.php
    but I'd like to find something from an easier source to deal with. The above folks don't seem to have any way to order online.
    nine,
    I believe that the odd graduated object is supposed to represent a slide rule. Graphics artists seem to take poetic license with anything remotely technical.
    Mike
    Feb 2006
    1072
    Quote Originally Posted by MichaelHenry View Post
    Thanks, Mike. I tried a Sanford(?) wax/china marker on an aluminum nameplate I engraved a while back (60-degree .005" point cutter in the primary spindle) without success because it was too hard and flaked off rather than rubbing into the lines. I'll hunt down an Engravocolor and try that the next time.
    Best regards,
    Randy
    Feb 2006
    1072
    http://www.gravostore.com/Home/ is their online store. But yeesh, the assorted 12-pack of the EngravoColor is $53.69 (plus postage, I assume.) It's under Engraving Accessories / Coloring Accessories on the second page. individual sticks are $8.11, a little more than wax pencils... It makes experimenting a little expensive. (edit) But if your old stick lasted that long, it's a long-term investment I guess!
    Best regards,
    Randy
    Jun 2006
    3063
    Randy,
    Thanks for the link - wonder how I missed that? The paints and brass blackening chemical also looked interesting.
    There must be other suppliers out there, but my web searches are mostly turning up UK vendors.
    Mike
  1. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  2. High speed spindle on PCNC?
    By laurentian in forum Tormach Personal CNC Mill
    Last Post: 02-09-2009, 01:04 PM
  3. High Speed Spindle Attachment
    By yoopertool in forum Hard / High Speed Machining
    Last Post: 06-20-2007, 12:26 PM
  4. High speed spindle friction fit?
    By Rhodan in forum Community Club House
    Last Post: 09-05-2006, 12:57 PM
  5. High Speed Spindle 10,000 to 40,000 rpm
    By whelen in forum Mechanical Calculations/Engineering Design
    Last Post: 09-05-2005, 02:42 PM
