586,213 active members*
3,646 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > cutter vibration or machine fault?
Results 1 to 15 of 15
    Jul 2010
    172
    I'm machining some cool 3d parts and some sections have odd cutter marks.
    It's as if the ball nose end mill is cutting at slightly different depths.
    You can see them but barely feel them with your fingers.
    I'm guessing less than half a thou.
    Interesting that their location is at the point where there is a double step.
    Plain round sections are flawless.
    I'm using a 1/4" 2 flute ball end mill sticking out 1.35" from the tool holder.
    6000rpm (max), 0.005" cut depth, 0.005" stepover at 24ipm.
    Wondering if its cutter vibration or is my Mini Mill worn out?
    Timothy
    Dyna Mechtronics DM4400, Bridgeport Discovery 300, HAAS VF-0E, HAAS VF-2D
    BobCad 16, 20, 24 and now V25
    Aug 2009
    1573
    Re: cutter vibration or machine fault?
    Try using G09 Exact Stop
    Jul 2010
    172
    I don't think a G09 will help.
    I added a small 5 thou radius in all the tight corners so the cutter wouldn't have to stop and it still makes those lines.
    I reduced rpm and cut the feed rate in half.
    Still no difference.
    Tomorrow I swap out cutters and tool holders.
    Timothy
    Mar 2008
    638
    I'll have this problem at times. I believe it's a problem between climb and conventional cutting since the path is a zigzag.
    I've minimized the problem by making the tool 2 flute and new. And if it's still an issue I'll make the path zig only. This adds a ton of time but when I have to, well, I have to and it works.
    does your mill have the high speed machining option , those machines can be pretty jerky without it . Also have you tried g187 ?
    There is a setting that adds a bit of rounding to smooth things out but it's been a while so I can't remember what setting it is
    Mar 2008
    638
    We have high speed machining. I’ve tried G187 P1 through P3 (its been a while so memory hazy). I ended up keeping it on the medium setting I think. Havent looked at it since the first experiments. I can look Monday. I was having the same problem on our new at the time VM-3 as our 5 year old VF-2ss. So I concluded it was just the nature of the beast but I sure hope there’s a better answer than mine.
    Jul 2010
    172
    No high speed machining.
    A G187 seems like it's just a G09 but for the whole program.
    Setting 85 is set to 0.005"
    I switched out the cutter for a new super high quality one and even put it in a brand new tool holder.
    Still the same.
    Then I changed the tool path to a climb mill zig only.
    Still there.
    What's really frustrating is that on other parts of this piece the contours are absolutely perfect.
    Since I bought this Mini Mill used, I'm wondering if there are some parameters that have been altered.
    Is there a quick way to reset to all the default settings?
    Timothy
    Oct 2010
    171
    Could you rotate your part 90 degrees, repost the program, and try cutting it again? If you have an axis issue, that might bring some things to light.
    To me, 1.35" hanging out on a ¼" cutter seems like a good bit, though you've made big changes in revs and feed with no apparent change, it sounds like? ER holder?
    PM
    Jul 2010
    172
    I rotated the part and ran a few different versions.
    The marks moved with the part to the new location.
    First ball end mill was in a side lock tool holder.
    Second one is in an ER20 collet.
    I'm leaning towards a CAM fault.
    The G19 circular path in made up of five or six segments in the problem area.
    The larger areas with no deviances from the circle are one or two circle segments and they are absolutely perfect.
    Timothy
    Oct 2010
    171
    Timothy,
    What are you using for CAM? If it's Fusion 360, and you don't have any secrecy-related issues... could you upload the F3D file or email it so I could take a look at it?
    PM
    flawed finishes aren't uncommon with haas but if rotating it produced the same results then it's going to be in the programming . a tighter tolerance in the cam software might help with blending oddball spots together better
    Jul 2010
    172
    I'm using BobCad/CAM Ver30 pro.
    And this job has a disclose agreement attached to it.
    Although I might be able to clip out a section...
    Which format is best for you?
    Timothy
    Oct 2006
    73
    Hi Timothy,
    I don't know if you ever got the answer you needed, but I've used Bobcad for 14 years to build molds from V21 through V30. The geometry problem you are seeing is purely bobcad's fault.
    1st: Make sure the model's surface normals are correct.
    - If any are inside out, fix them re-select the geometry and recalculate the tool path.
    2nd: Play with the accuracy settings in Bobcad.
    - Arc fit, corner rounding, smoothing, and general tolerances all play a part in the delicate ballet of calculating the best tool path.
    - Counter-intuitively, Tightening tolerances may not always be the right answer. Bobcad might detect micro deviations in a model's surface that aren't rendered on screen and therefore jitter bugs the tool across the surface. Loosening tolerances may let Bobcad ignore these imperfections and smooth the tool path.
    - Sometimes if you blank the model and zoom in on the toolpath from the correct angle you can actually see on screen the gouging moves.
    Machine settings are important too, but I'm sure Bobcad bears the most blame here.
    https://youtu.be/vt7rVVRiiKk
    https://youtu.be/lwujoXvgGzA
    Good Luck, I hope I was able to help.
    Jul 2010
    172
    Thanks for the reply bishb25,
    I did change a few setting within BobCAD but I didn't see any differences when running the part.
    I have another batch coming up in a few weeks so I'll try G187 and see it that fixes it.
    At the same time I'll look real close at the tool paths to see if anything is out of place there too.
    Timothy
    15362
    Quote Originally Posted by 2ferrous View Post
    Timothy
    The cutter is having a merry old dance
    Mactec54
  1. Replies: 0
    Last Post: 02-05-2019, 11:13 AM
  2. buying a machine with Y axis vibration
    By ned_seven in forum Chinese Machines
    Last Post: 04-26-2017, 12:33 AM
  3. Machine vibration analysis
    By EvilSpeeder in forum DIY CNC Router Table Machines
    Last Post: 07-06-2015, 12:42 PM
  4. Chinese Laser cutter Fault
    By bluestorm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-24-2014, 03:57 PM
  5. vibration problem with new machine
    By rppman in forum Knee Vertical Mills
    Last Post: 11-03-2009, 03:58 AM
