586,065 active members*
4,842 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > went from a hand held torch to a machine torch Herpertherm 45 to a 85. Plasmacam
    Sep 2019
    the ground that goes to the copper nozzle I don't seem to get a solid ground.
    Nov 2010
    177
    Re: went from a hand held torch to a machine torch Herpertherm 45 to a 85. Plasmacam
    The design of that ohmic sensing ring is bad. You should either replace it with a new one, or you can TRY to bend the tab down to make contact with the shield.
    One of my clients who hired me to train him on how to use the DesignEdge software for his PlasmaCam table did the "one Cent Fix." He slipped a copper penny between the tab and the shield, and the contact was made.
    You can alternately wrap a hose clamp around it and use the clamp to pinch the tab to pull it in to contact the shield. Some people use a solid copper wire or even a copper oil drain plug washer and slip it between the tab and the shield.
    Honestly, it is a BAD design. The tab MAY contact the shield when it is cool, but after cutting, it gets hot so it bends out from HEAT like a thermostat, and then bends back to re-establish contact when it cools again.
    MOST of the height control sensing issues on a PlasmaCam table can be traced to that failed contact between the ohmic sensing tab and the torch shield.
    Joe
  1. Does a machine torch perform better than a Hand Held
    By Marankie in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-19-2014, 09:51 PM
  2. Wanting to change my Hand Torch to a Machine Torch?...
    By winegar in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-14-2014, 09:38 PM
  3. Plasma torch: machine head vs hand-held
    By jeepsterjc in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-06-2012, 03:27 PM
  4. hypertherm 1000 hand torch to machine torch
    By duraflap in forum Hypertherm Plasma
    Last Post: 05-18-2010, 08:34 PM
  5. Replies: 0
    Last Post: 04-18-2008, 03:09 PM
