586,069 active members*
3,402 visitors online*
Thread: Haas VF help
Results 1 to 6 of 6
    Mar 2013
    66
    Haas VF help
    Vintage 1998 HAAS
    When my tool holder grabs a tool and the spindle starts, there is a delay when set at any speeds above 2000 rpm, if I am doing an aggressive adaptive clearing I have to FEED HOLD right above work and wait about 5 sec for vfd to ramp up, if I dont it plows in, at low speed and then eventually alarms out shutting down. Anyone know why it would delay before going full rpm? I noticed this after losing my original HAAS .post file.
    Aug 2009
    1573
    Re: Haas VF help
    check Parameter 209 bit 31 (SPNDLE NOWAIT)
    https://www.haascnc.com/content/dam/...ual---2002.pdf
    PAGE 278-279
    Mar 2013
    66
    Re: Haas VF help
    Thanks for the response, I cannot find that parameter even though its in my book, I am on the 209 par page also???
    Aug 2009
    1573
    Re: Haas VF help
    YW.
    Did you use the? ............."The left and right cursor arrows are used to select the function being changed. All values
    are 0 or 1 only."
    DJ
    Mar 2013
    66
    Re: Haas VF help
    I know how to change it, just cannot find that parameter on my list under 209
    Mar 2013
    66
    Quote Originally Posted by repauli1 View Post
    A work around I put a G4 P2500 right after the G54 move (Dwell 2500ms)
  1. HAAS HA5C on Matusra RA2F - Issues with 2 different HAAS Rotarys/Indexers
    By bjstratton84 in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2016, 04:08 AM
  2. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
