586,108 active members*
3,027 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Pin out of CTRL connector on MK3 and truth tables
Results 1 to 5 of 5
    Jan 2007
    31
    Hello,
    I have tried to connect some pendant I have on the CTRL connector of a recently purchased MK3.
    I found out that the pins MD1 and MD2 , and also the AX1 and AX2 are not standard in terms of configured logic.
    Please see the table attached.
    Attachment 434394
    Could you please provide the logic tables I should follow to wire my MPG correctly?
    Should I use also the [EN3A/MD3, EN3B/AX3] for the 4th axis and additional modes?
    I ask this because the configuration (MD1, MD2) = (HIGH, HIGH) and (AX1, AX2) = (HIGH, HIGH) do not configure any axis or mode! (or maybe I am wrong).
    But a truth table that MK3 understand would realy help.
    Apart from that, does anybody know if I should use all four pins (A, B, /A, /B) of my rotary encoder or only the first two?
    Using only the first to (A, B) and leaving unconnected the long drive outputs (/A, /B) seems to work fine.
    - Petros
    Feb 2018
    6
    Re: Pin out of CTRL connector on MK3 and truth tables
    I hope the following links will help you.
    https://planet-cnc.com/how-to-connec...p-mpg-pendant/
    Mar 2017
    1312
    You should also use MD3 and AX3 pins for more modes/axes.
    Mode (HIGH, HIGH) is "mode zero".
    Axis (HIGH, HIGH) is "disable"
    Jan 2007
    31
    Thanks for the replies.
    The exact configuration as I probe it is
    Attachment 434578
    Where 0 is GND and 1 is 5V from some pin on MK3.
    Mar 2017
    1312
    Pins are pulled-up. There is no need for 5V. If you left pin unconnected then this is 1,
  1. OP connector sanyo denki servo PV drive - looking for connector
    By gm276 in forum Want To Buy...Need help!
    Last Post: 12-15-2018, 07:39 PM
  2. The truth and nothing but the truth
    By Acebull in forum DIY CNC Router Table Machines
    Last Post: 08-18-2013, 03:59 PM
  3. CTRL [
    By Jay Roy in forum GibbsCAM
    Last Post: 12-02-2010, 06:12 PM
  4. Layup tables, cmm measuring tables??
    By ARE 416 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 10-22-2010, 03:06 PM
  5. Ctrl-PgDn does not jog
    By milhead in forum Mach Mill
    Last Post: 02-02-2010, 01:37 AM
