586,036 active members*
3,823 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > FANUC CNC retrofit controller. Control relays, pumps, lights, valves. Interested?
    Jan 2020
    12
    I've developed a controller that "spies" on the RS232 port of a CNC machine and reacts to specific data to manipulate a few 10 amp relays. As long as your machine can DPRNT from within the Gcode program, you can use this device. I use it for a solenoid valve to provide air blast for milling and an in-process buzzer to keep the machine from sitting idle. I can keep the project simple and cheap ($) where you wire up the peripheral electronics you want or I can enclose it all in a watertight box along with a solenoid air valve and buzzer ($$$) This will be a great addition to any CNC machine!
    One could use the 10A relays provided to trigger more powerful relays to control things like dust collection or other large devices. I figure 3 small relays would be a good start.
    Configuration is done on a PC. Drag and drop some setup files on an SD card for the machine's COM port settings.
    I haven't figured out a single way to produce the device yet,such as enclosed with all options or bare bones... I'm interested in what you would like to see.
    Let me know if you are interested, I'm excited to get this thing out there!
    Jan 2020
    12
    Re: FANUC CNC retrofit controller. Control relays, pumps, lights, valves. Intereste
    Here's a sketch of the DPRNT relay control unit.
    Jan 2020
    12
    Here is a video of a prototype unit in operation. Sorry about the bad editing, it was my first ever attempt at a video.
    https://youtu.be/F51v8tvJK2M
  1. Flow control valves in Australia for 1 shot oiler? And other fittings?
    By j3dprints in forum Australia, New Zealand Club House
    Last Post: 02-12-2019, 04:29 AM
  2. HELP! Control Panel not on! (no lights)
    By 6345789 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2015, 11:27 AM
  3. plug compatible Fanuc control retrofit
    By memoryman in forum Fanuc
    Last Post: 09-25-2012, 12:24 AM
  4. Replies: 0
    Last Post: 04-28-2011, 01:32 AM
  5. Fanuc 0TC control retrofit
    By Motopsych in forum Fanuc
    Last Post: 08-30-2010, 01:35 AM
