586,080 active members*
3,572 visitors online*
Results 1 to 7 of 7
    Jan 2007
    5
    Exclamation VF 0 Spindle problems
    Just had my VF0 give me a bunch of trouble. As it goes to up to speed (3000 rpm) it seems to take a longer time to get up to rpm. and as it comes back down from rpm it errors out and gives a spindle overheating, overload error....ect It also seems to make a hollow cluck noises when it gains rpm and again when it slows back down. please help
    4826
    Start with the basics. Can you revolve the spindle readily by hand?
    Does this machine have a gearbox?
    Did it make the noise while running normally at 3000 rpm, or did it only begin making the noise after starting up?
    Jan 2007
    5
    It still revolves. It has a gear box and it did during start up
    Feb 2007
    205
    VF-0's don't have gearbox. VF-1B or VF-2B has gearbox.
    Your delta/wye switch in the control cabinet could of gone bad.
    Jan 2007
    5
    It is a 2 speed, thought it was controlled by a gear box but may be something else
    Jan 2007
    5
    could this possibly be spindle bearings
    Feb 2007
    205
    Turn the spindle by hand with E-stop on. If it moves freely .. I doubt it's bearings.
  1. Fadal Spindle Problems?
    By TurtleRacing in forum Fadal
    Last Post: 08-25-2007, 03:11 PM
  2. Fanuc 3tc spindle problems
    By R.thayer in forum Fanuc
    Last Post: 04-14-2007, 09:15 AM
  3. spindle problems
    By IeatSteel in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2006, 07:23 PM
  4. 15XT Spindle Driver Problems
    By integral in forum Fadal
    Last Post: 08-22-2005, 08:25 PM
  5. spindle problems
    By hofi in forum DNC Problems and Solutions
    Last Post: 02-07-2005, 07:34 PM
