586,645 active members*
2,904 visitors online*
Results 1 to 11 of 11
    Dec 2016
    14
    Circle problems
    hello everyone. I have a problem with machining circles. everything seems good if I just make one pass, but if I want to go deeper than one cut then as the cutter descends into the material the Y axis moves in a minus direction. It has to be something to do with settings I feel sure because it moves the same amount over with each cut down but I can not see what the problem is, can anyone help me out please?
    thank you
    Jun 2005
    1730
    Re: Circle problems
    You provided no background info. What software are you using, what kind of material are you cutting, what kind of cutter, pictures, videos, etc.
    Russ
    Sep 2011
    25
    Also machine type,control type, sample of program in machine would be of help.
    Dave
    Dec 2016
    14
    Re: Circle problems
    sorry guys I did try to add before but doesn`t seem to of been posted,I tried to add as an answer . I have a small 3018 machine that I changed over from grbl to mach3 the cut a circle wizard which comes with mach3 was how I was trying to cut the circle. I have closed all cv settings and I am running the motors under tuning the same acc and vol. hop this helps
    Dec 2016
    14
    Re: Circle problems
    hello hope this pic tells the story of the problems I am experiencing
    Dec 2016
    14
    Re: Circle problems
    I have tried to post a pic but is not working ? anyone advise please?
    thanks haz
    Dec 2016
    14
    Re: Circle problems
    this is a picture of my problem after running cut a circle to a depth of .8mm .1mm per cut can anyone please assist?
    thank you Haz
    Jun 2005
    1730
    Re: Circle problems
    This on the surface appears to be the Steps per Unit are set wrong on the Yaxis. Post your gcode you are running to do these tests. My friend has this same machine and it still has the GRBL controller but it cuts circles fine.
    Russ
    35538
    Re: Circle problems
    Looks like it's losing steps in the Y axis. Do you have backlash comp enabled?
    Jun 2005
    1730
    Re: Circle problems
    Clearly Gerry could also be correct. Also check coupling tightness on that axis. My friend has same machine and his coupling came loose a day after he started using it.
    Russ
    Dec 2016
    14
    Re: Circle problems
    thank you Russ for your input. I just reloaded mach3 066 version and all is good, think I need to download some files to keep win10 stable with usb mach3 running properly with the plugin bl-usbmach v2.2 so need to look into that . have a good day
  1. X Y axis calibration, engraving and circle cutting problems.
    By Albert-Bristow in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-24-2019, 09:34 PM
  2. Circle problems
    By Patuc in forum DIY CNC Router Table Machines
    Last Post: 03-18-2018, 10:10 PM
  3. Circle and arc problems
    By antoinedrouin in forum G-Code Programing
    Last Post: 07-07-2017, 10:05 PM
  4. Draw line tangent from small circle to large circle
    By WEDDLETON in forum ViaCad / Shark
    Last Post: 07-30-2014, 05:53 AM
  5. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
