586,069 active members*
3,410 visitors online*
    Jan 2020
    Removing Tool Marks in Acrylic
    Hello,
    I'm relatively new with CNC work. I'm pocketing designs in mirrored acrylic, and I'm wondering if there is a good way to eliminate the tool marks left from the path in the acrylic. The attached photo shows the marks I mean. I'm cutting 1/8" thick acrylic to a depth of 1/16" with an Amana Tool 51517-k Spektra Coated single flute down cut bit recommended to me for plastic cutting. I'd prefer not to have to do any sanding or buffing by hand if possible. Thanks!
    Dec 2013
    5717
    Re: Removing Tool Marks in Acrylic
    The best way is not to generate the tool marks to begin with, I use soybean oil, just brushed on or applied with an oiler, seems to work pretty well. Also keep the chips evacuated so they are not being recut.
    Also Google: flame polishing acrylic
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2008
    683
    Use an up cut bit for pocketing. And play around with finishing passes.
    Jan 2020
    Thank you Jim Dawson, I will try those!
    - - - Updated - - -
    Thank you warrenb, I'll try that too!
    Jan 2007
    626
    I've waved a flame gently over cut acrylic and removed a lot of the cutting marks. ( hand held gas torch)
    It might pay to practice on scrap before you go balls deep....lol
  1. Laser "Tick Marks" on Acrylic from Rabbit
    By micmouse10 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-18-2017, 03:16 PM
  2. Removing burn marks on card
    By Pickup in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-15-2015, 03:19 PM
  3. How to eliminate heat marks from blade table on acrylic?
    By mirbearium in forum Community Club House
    Last Post: 07-05-2013, 04:55 PM
  4. Tool marks....GAH!
    By mlabruyere in forum DIY CNC Router Table Machines
    Last Post: 10-29-2010, 04:25 PM
