586,096 active members*
3,707 visitors online*
Results 1 to 15 of 15
    Feb 2019
    76
    Laser cutting PostProcessor
    Can I make a postprocessor for laser cutting in ArtCam, or Vectrics? What would the laser (which is connected to the PWM output of the spindle) be switched off at the time of transition?
    I can not find a program in which you can generate the g-code for laser cutting.
    Mar 2017
    1312
    Re: Laser cutting PostProcessor
    There is really no difference between laser and spindle. They are controlled the same way.
    Feb 2019
    76
    This is clear. But in the control program, the spindle turns on at the beginning, and turns off at the end of the whole program !!! But it is necessary that he turn on only when the laser approaches the desired cutting point, and turn off at the output of the part. Do you understand?
    Mar 2017
    1312
    This is an easy change. I will make them for Vectric. ArtCAM software has been discontinued since 2018.
    Feb 2019
    76
    When will he be ready? I did not find it in the new version of TNG.
    Mar 2017
    1312
    Vectric Aspire v10.019 update which fixes some bugs was just released. It fixes some bugs in their postprocessor engine. I can start working on them now.
    Feb 2019
    76
    Can you do it in artcam? this is done in 5 minutes.
    Feb 2019
    76
    I did it myself, it takes even less than 5 minutes. I don’t understand what difficulties you had.
    Mar 2017
    1312
    Main difficulty is, that ArtCAM is discontinued since 2018. I don't have it and it no longer exists.
    But why are you asking me to do something that you can do yourself in 5 minutes?
    Feb 2019
    76
    Because when I asked, thought it was difficult. And then I tried it and it turned out easy. True, I'm not sure that it will work correctly in 100% of cases.
    In addition, you have written that MK3 / 4 can be used with a laser, although it is not written anywhere how to do it. Have to come up with something yourself.
    Feb 2019
    76
    why does the speed of movement drop on command M3? the machine moves jerkily.
    Attached Files Attached Files
    Mar 2017
    1312
    Check what script do you gave on your M3 command.
    I just posted a video on Facebook showing my little DIY laser.
    Feb 2019
    76
    Quote Originally Posted by PlanetCNC View Post
    I did not change anything, all the default settings. where to see this script?
    Feb 2019
    76
    so with a stop at the M3 command do ??? or make a normal laser postprocessor.
    Mar 2017
    1312
    M3 calls subprocedure which causes synchronization.
    You need to remove those M3 commands from your g-code. They are redundant.
    Did you see my latest laser videos on Facebook:
    https://www.facebook.com/pg/planetcnc/posts/
  1. Replies: 2
    Last Post: 05-30-2020, 08:55 AM
  2. CamWorks or Solidworks CAM laser postprocessor
    By maparkopo in forum CamWorks
    Last Post: 10-22-2018, 08:41 PM
  3. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2015, 09:03 AM
  4. PostProcessor for WaterJet cutting machine
    By cutleader in forum CutLeader
    Last Post: 12-05-2013, 01:25 PM
  5. Replies: 0
    Last Post: 09-30-2012, 11:35 AM
