586,080 active members*
3,563 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > bridgeport interact 1 mk 2 ktk drive board probs
    Aug 2018
    hello all hope someone can help had a few problems with my interact ,its nearly there apart from a spindle problem ,when I use the m3 or m4 command the spindle wont spin ,two of the led's on the ktk sol 1 board go dim ,if I press the reset button on the ktk fac board the spindle briefly rotates then stops,ive changed a few of the obvious caps so far ,, are there any circuit diagrams available for the ktk boards pls ,any help much appreciated,
    Oct 2018
    4
    Re: bridgeport interact 1 mk 2 ktk drive board probs
    Here is the KTK Drive Maintenance manual and the Manual. I had similar issues with the spindle, ended up being a zener diode on the +-12V rails.
    https://drive.google.com/open?id=0B9...5oSlBjOWF4RXpr
    https://drive.google.com/open?id=0B9...Z3VElxcTNDbk9V
