586,052 active members*
4,210 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Getting different results when changing the feed rate on my machine.
    I am getting different results when changing the feed rate on my machine. When the feed rate is slower the engraving looks a lot better. Anyone know what would cause this?
    When you look at the picture of the two "e"s the first "e" was done at a higher speed and the second "e" was done at a slower speed. So my question is what the hell would cause this? We replaced the bearing blocks on the X axis do we need to replace them on the Y axis too?
    Apr 2004
    5737
    Re: Getting different results when changing the feed rate on my machine.
    It looks like the second one is carved deeper than the first; all the V-cuts are wider. Did Z change position from one to the other?
    Andrew Werby
    Website
    Quote Originally Posted by awerby View Post
    It was the brush on the dust boot. Everytime it went down to carve the brush was pushing against the workpeice and moving the spindle. So I just cut the brush shorter.
    1227
    Quote Originally Posted by Rschaeffer83 View Post
    That looks like a fairly clear sign of a flexing machine.If a few bristles can cause a distortion you might want to look around the whole machine carefully.
  1. Problem with feed rate not changing
    By jcrouch in forum Mach Mill
    Last Post: 12-26-2017, 03:49 PM
  2. Z feed rate changing! Please help!
    By DasNewb in forum Tormach Personal CNC Mill
    Last Post: 01-22-2016, 01:44 AM
  3. How can I increase the feed rate of my machine?
    By Ranscon in forum DIY CNC Router Table Machines
    Last Post: 03-05-2009, 10:00 PM
  4. c axis feed rate on a turn /mill machine
    By bike in forum G-Code Programing
    Last Post: 09-30-2008, 12:57 AM
  5. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
