586,119 active members*
3,500 visitors online*
    Jan 2020
    Buying used??
    New to CNC. Looking at buying used Shop Sabre Sidekick 8. The set up is 3 years old. Table, Powermax 45XP, Sidekick router package. Is this a good decision or should I just look at new? What should I be careful of?
    This is for a hobby shop, that hopefully can grow to pay for its self.
    Jan 2010
    77
    Re: Buying used??
    It depends on the price you are at. I prefer used, but I can fix them myself. Lifetime tech support is only offered to the original owner. If that is important to you, get a quote from shopsabre on that. I have moved on to a different brand machine, but the shopsabre I had did pay for itself.
    Jan 2020
    Re: Buying used??
    Thanks Ken. 24k for “turn key” set up. Including table plasma cutter, router, software, compressor. The supporters is one of my concerns. This will be me first table.
    What system did you upgrade to?
    Jan 2010
    77
    Re: Buying used??
    That seems expensive for used. If it's your first machine, add in support cost. Price it all out new and compare. Find a few shops using that same machine and visit with them. What do they like and dislike about it. I am running axyz now, but router only. Switching cutting heads is the easy part. Switching material hold down systems is a huge pain.
    Jan 2020
    Re: Buying used??
    Thanks. I was concerned on cost Seamed I bit high from what I have been seeing. I have been looking around but have not found a shop using this machine locally. I’m sure I will be needing the support.
  1. Buying a machine soon..any tips before buying?
    By TSHobbies in forum PlasmaCam
    Last Post: 11-09-2016, 03:22 PM
  2. Buying a CNC
    By IvanPoole in forum Commercial CNC Wood Routers
    Last Post: 05-29-2010, 10:51 PM
  3. might be buying a TM
    By CenTex Fab in forum Torchmate
    Last Post: 02-15-2010, 05:03 PM
  4. Buying a CNC, what to get?
    By frankgant in forum Want To Buy...Need help!
    Last Post: 05-21-2008, 04:47 AM
  5. Help with buying my first CNC
    By stabbs in forum Benchtop Machines
    Last Post: 01-06-2007, 08:45 AM
