Originally Posted by
One of Many
Interpolation is handled by the control to take code that intends to do an arc and mix multiple axis motion in terms of distance and velocity to achieve the proper ratio to follow that path.
As I read the PDX data sheet, I do not see that as an option. Sure, you can create accel/decel profiles, but once the go command is given to individual drives, they do not synchronize that profile to follow the profile under control of a common cpu that looks ahead to mix those signals or code together in order to maintain that path.
Even with the Galil to Mach3, there is a common CPU in the Galil controller and I suspect an interpreter type of post processor within Mach3 to convert G-code into something the Galil motion control comprehends. With this scenario, the brains control the limbs. With the PDX, individual brains are in each limb, but do not communicate amongst themselves in order to cooperate in a controlled manner.
Possibly making contact with a Parker applications engineer might be the best bet to find out if there are programming features to support what you are attempting to use these drives for?
I am afraid my speculation and conjecture isn't being much help. My intentions are not to discourage your efforts. I am just pointing out glitches and possible road blocks you might find along the way.
DC
