Originally Posted by
joeavaerage
a shielded VFD/spindle cable is highly recommended, it should reduce the amount of electromagnetic noise from being radiated in the first place.
The shield should be earthed at one end only, the VFD end, and it should go to the common ground point for all other earths in your machine. Most VFDs provide a clamp
that connects the shield direct to the VFD case, and that's not bad, but better that it go to the common earth. It's commonly called the 'star point'. If you make the mistake
of grounding your shield at the spindle end AND the VFD end, then you would have a loop which could introduce noise currents even worse. If you earth the shield at the
spindle end only, it may reduce the electromagnetic radiation but would cause noise currents in the earth wire from the frame of the machine
to the star point and you may have a worse problem than no shield at all.
As I posted earlier my spindle cable it not shielded at all and I have no insurmountable noise problems, shielding is nice and recommended not absolutely required.
Craig
