586,096 active members*
3,112 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > resetting alarm without resetting program??
Results 1 to 6 of 6
    May 2016
    6
    anyone know how to reset an alarm without resetting your program?
    for example, i'm running a program and about 10 minutes into i pause and blow out chips, but accidentally trigger a low air pressure alarm - now i'm screwed! the only way to get the program to start again is to get rid of the alarm, and the only way to get rid of the alarm is to hit the reset button, which resets the program!
    am i stupid, or is haas stupid? what am i missing here?
    Mar 2010
    1852
    Re: resetting alarm without resetting program??
    Yeah, Haas is stupid---Right!
    They did provide a way to restart your program at any position in it, probably just for such occasions.
    Aug 2009
    1573
    May 2016
    6
    thanks! that's exactly what i needed to know.
    Mar 2010
    1852
    Stupid Haas even had this feature on the older machines/controls , same setting number. (you did not say what year your mill is) If you don't have a copy of your manual, I would go online and download a digital copy.
    Good luck
    You can also change setting 31 to off and when you hit reset it does not change the position of the pointer in the program and also turn on setting 36 for Program restart.
  1. resetting a ST-28 MAZAK
    By emersonja in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-04-2018, 04:32 AM
  2. Resetting y axis alarm
    By jimmy111 in forum Fanuc
    Last Post: 11-01-2013, 07:03 PM
  3. Resetting X0 Y0 Z0.
    By Witsenburg in forum Mach Software (ArtSoft software)
    Last Post: 06-05-2007, 03:39 PM
  4. Resetting the top view ?
    By altered in forum Mastercam
    Last Post: 03-17-2007, 10:03 PM
  5. resetting fields
    By hogman in forum GibbsCAM
    Last Post: 05-06-2005, 02:22 AM
