586,312 active members*
3,275 visitors online*
    Jan 2013
    12
    Acme thread cutting
    I run a Harrison alpha 550 everyday. The acme threading with it is terrible. I have tried a program that was supplied by Harrison to stagger acme threading. But it was terrible!
    I am cutting a 4 acme in 1018 tubing. The OD of the pipe is 5”. Thread length is 23”. I need a way to stagger the carbide insert from the left side to right side. Any side first. Don’t matter. I just need the code. It’s a Fanuc controller. Can anyone help with this please?!
    2932
    Re: Acme thread cutting
    What model of Fanuc?
    Jan 2013
    12
    Quote Originally Posted by dcoupar View Post
    Machine says Harrison - GE Fanuc
    2932
    A caveat: I last used this about 20 years ago, so I may be way off base, but I thought it might be worth a try. In any case, proceed with extreme caution.
    Some older Fanuc/GE Fanuc controls had the ability to use F10/11 single-line Multiple Repetitive Cycles, including G76 which allowed staggered thread cutting . The downside is that ALL of your G70-G76 cycles have to be F10/11 style. Check your (SETTING 2) display. If there's a setting for TAPEF you might try changing TAPEF = 1. The programming format is explained in the Operator's Manual.
    May 2016
    526
    D Coupar
    Normally I'd agree but the control on the Harrison only allows it to be programmed via a conversational type of cycle not g code
    To vary the flank entry he would have to program using the offline Alphalink system that was supplied with the machine
  1. Replies: 3
    Last Post: 02-13-2017, 08:21 PM
  2. Replies: 0
    Last Post: 02-03-2017, 11:38 AM
  3. tooling for cutting off acme thread?
    By shootingarts in forum MetalWork Discussion
    Last Post: 01-13-2008, 04:17 AM
  4. Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help
    By pandiyan.innova in forum Community Club House
    Last Post: 11-16-2006, 12:47 PM
  5. cutting acme thread
    By barnesy in forum MetalWork Discussion
    Last Post: 09-02-2006, 03:06 AM
