Re: Mach 4 running tool off the table at the start?
Originally Posted by
jamesfiore
I feel it is something to do with units, as the current position indicator will say the tool has moved a few mm but in reality it has moved half way across the table. In configuration I have everything set to metric but maybe I am missing something?
If you want to work in metric double check the configuration is set to metric.
If that checks out revisit the motor tuning and make sure the pulses/unit (or whatever Mach4 calls it) is set correctly. Mach4 will have a manual explaining the math.
The steppers are most likely 200 steps/rev, don't forget to include any micro-stepping in the calculation.
edit/ A quick google shows Mach4 terminology is 'Counts per Unit'
