586,060 active members*
4,185 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > V-groove carve job, depth and corners problems
    Feb 2013
    81
    I have a job to do over this weekend and its stumped me. Its a milling job for two letters on a circular background one raised and one indented in beech.
    I worked out a strategy a couple of months ago for this job using a large 120 degree 48mm diameter v-groove bit and some unusual profile paths instead of vcarve or prism carve path strategies. However true to circumstance I have to have the job done by Monday (its Friday night now) and I doubt I can get a 48mm 120 degree v-bit has now asked to have the piece but I do have a 120 degree v-bit at 22mm. Final disk is 450mm diameter (18”)
    My question is what tricks am I missing so that I can just use my 22mm diameter 120 degree v-bit cos there is no way i’m going to be able to source a 48mm diameter v-bit in time? The client wants a reasonable height/depth to the letters and sharp ext and int corners and the height centre in each letter. Am I missing something obvious in the vcarve prism strategies perhaps?
Name:	final version.jpg
    Feb 2013
    81
    Re: V-groove carve job, depth and corners problems
    Well by rescaling the origin file, changing the 120 degree v-bit to 90 degree and using the profile, inside and outside method I resolved the problem, see pic.
    New issue, i've removed so much material that its curling up at both sides...
  1. Replies: 5
    Last Post: 03-17-2019, 05:05 AM
  2. V-Carve flat depth problem
    By darkclown in forum Aspire
    Last Post: 04-04-2018, 04:42 AM
  3. 2d/3d how-to carve piston groove
    By CNC_Kid in forum ViaCad / Shark
    Last Post: 01-06-2014, 06:04 PM
  4. Vectric photo carve depth?
    By Wyndham in forum Vectric
    Last Post: 09-15-2012, 05:39 PM
  5. problem with depth in v carve
    By timmyb199 in forum Vectric
    Last Post: 11-01-2006, 06:42 AM
