586,102 active members*
3,343 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Cnc 6040 advice for new electronics
    Apr 2017
    7
    sorry for my English Hi everyone I wanted to change electronics the current one creates me many problems of loss of pace.
    Some time ago I had to replace the drive of the z with the 4 axis because it was now gone.
    After some tests I realized that the x and y are also the drivers in question are the tb6560 abbreviation 14207 the control card parallel port abbreviation 14175
    Apr 2017
    7
    Re: Cnc 6040 advice for new electronics
    As for mechanics
    X, Y, Z working area: 600 (Y) * 390 (X) * 120 (Z) mm
    External Dimension: 865 * 680 * 570mm (L * W * H)
    6063/6061 aluminum alloy structure
    X axis in 1605 ball screws
    Y axis in 1605 ball screws
    Ball screws Z axis 1204
    57 two-phase motors 3A 150N.cm x y z
    the 4th axis mounts a 57 1.5A motor
    1500w water cooled spindle
    Since I don't understand much of electronics I would need advice on what to buy I saw a stepperonline kit
    https://www.omc-stepperonline.com/it...ionamento.html
    besides this kit I would like to take an inverter and board board parallel port use mach3.
    Usually wood work I would also like to do a little something on aluminum I have a budget 350 euros I would like to take power supply motors and drivers on that site and if the inverter case and parallel board board somewhere else.
    Could you give me some advice how to coordinate everything considering also the mechanics I have.
    I wanted to take everything there but the seller told me that with that inverter kit and board they were not going well.
    I would like to take everything on that site I have difficulty coordinating everything.
    Thanks in advance to those who can help me.
    Apr 2005
    304
    With your parallel BOB is quite enough for controlling 4 motors. For drivers you can use these: https://www.aliexpress.com/item/3282...chweb201603_53
    4A/42V
    Do you have inverter for your spindle?
    Attach photos of your electronics for machine.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Apr 2017
    7
    thank you for the help these are the photos spindle card is 1500w also the water cooling spindle is 1500w but my idea was to change everything I wanted to buy power supply, driver, motors, parallel control card and inverter.
    my problem how to coordinate everything having that type of car.
    I wanted to take at that site at least motors power supply drive parallel control board thank you.
    Apr 2017
    7
  1. 6040 CNCEST USB 1.5KW Spindle and BOB electronics
    By vondeliusc in forum Chinese Machines
    Last Post: 02-17-2023, 11:14 PM
  2. HY-6040 CNC w/ ALL NEW electronics and G540 - COMPLETE
    By Shawn_M in forum For Sale Only
    Last Post: 08-13-2019, 11:11 PM
  3. Replies: 5
    Last Post: 07-17-2019, 04:34 PM
  4. Building a new electronics box for my 6040, need advice
    By DaMaDo in forum CNC Machine Related Electronics
    Last Post: 05-30-2019, 01:52 PM
  5. 6040 limit switch advice
    By rthorntn in forum Chinese Machines
    Last Post: 04-11-2018, 12:08 PM
