586,108 active members*
3,067 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA CROWN CNC LATHE OSP700L LEAVING SPINDLE RUNNING
Results 1 to 8 of 8
    Hello
    I am a newbie to Okuma anything. I am programming an Okuma Crown CNC Lathe with an OSP 700L controller. i was wanting to know if i could leave the spindle running while going to tool chance position and changing tools to save time waiting for spindle to ramp up. i could shorten my tool change position but no need if i have to Waite for spindle to ramp up
    thanks for any help
    TingerrFann
    Jun 2015
    4154
    Re: OKUMA CROWN CNC LATHE OSP700L LEAVING SPINDLE RUNNING
    hy tiger, remove M05 from code
    please, can you describe a bit more how you wish to shorten the tool change position ? kindly
    Feb 2011
    353
    Quote Originally Posted by tigerrfann View Post
    Hello
    thanks for any help
    TingerrFann
    !st question should be yes by not placing an m5 at the end of the tool code before the next tool call
    second i can't answer for sure as i run an lb15 with the osp5020 control but the manual say's that if you have a servo driven turret you can
    1) unclamp the turret before going to the safe index point
    2) index the turret
    3)clamp the turret going to the position point for the indexed tool
    care must be taken when doing this
    maybe THEOKUMAGUY can chime in on this his answer are usually pretty good
    there is also a setup reduction post that is good to look at
    Apr 2006
    111
    People do not understand the question.
    When running the program on a lathe, if the program has a command to change the tool, the lathe will move the turret to a certain position, stop the spindle, change the tool, run the spindle to continue. He wanted to ask if there is any way that when changing a tool there is no need to stop the spindle? to shorten machining time. The time to stop then run the spindle takes about 3 to 15 seconds depending on the machine.
    In my opinion it is in parameter, but I don't know which parameter, because I don't have the documentation of the machine.
    Shorten tool change , change where machine home is make it closer to spindle.
    i need the M05 so i can use bar puller
    i just want to leave spindle running during tool change.
    Apr 2009
    1262
    Yes you can just do G97 S1500 G0 X20 Z20 (tool change position)
    If you add M203 to the line the turret will unclamp during the rapid move on servo turret machines.
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    hy mr wizard, that one really works for modal m63
    Apr 2009
    1262
    Yes:
    G97 S1500 G0 X20 Z20 M203 M63
    ( will rapid away, not wait for RPM arrival, and unclamp the turret during rapid)
    X1 Z1 S2500 M63 T010101
    ( will rapid to part, not wait for RPM arrival, and clamp the turret during rapid)
    Good for at least 1.5 sec reduction each index. More depending on RPM change.
  1. Okuma Cadet OSP700L
    By SINUMERIKO in forum Okuma
    Last Post: 03-01-2021, 05:45 PM
  2. Okuma OSP700L Ball Bar Program Need Help
    By portej5 in forum Questions or Problems
    Last Post: 07-19-2016, 04:08 AM
  3. Replies: 0
    Last Post: 09-06-2015, 03:18 PM
  4. Okuma Crown Lathe Tailstock Assembly
    By AlexP in forum Okuma
    Last Post: 09-06-2015, 03:08 PM
  5. Replies: 3
    Last Post: 04-15-2013, 05:56 PM
