586,067 active members*
4,749 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > Designer Series Gantry not sitting Square on side rails
    Jan 2020
    9
    Hi
    Just purchased a 2002 designer series 2400 x 1200 table
    The gantry dosnt sit square on the side rails so not all bearings are touching at the same time. When i measure from the gantry to the end of the table there seemes to be around 4mm diference left to right . How do i rectify this
    Jun 2018
    362
    Re: Designer Series Gantry not sitting Square on side rails
    Photographs of the machine and the structure/mounting arrangements of the gantry and table would go a long way in helping others help you :-)
    Use the "Advanced" setting of the Forum to attach photographs.
    Apr 2004
    5737
    Is the gantry bent? Is the table warped? Or is something in between grossly out of adjustment?
    Andrew Werby
    Website
    Jan 2020
    9
    Hi Guys
    Spoke to multicam today who said the gantry must have jumped a tooth in the move . Told me how to fix it . Thanks for the replies
  1. square AND round rails!?
    By jschoch in forum Linear and Rotary Motion
    Last Post: 06-20-2018, 06:29 PM
  2. Budget square rails
    By andy1989 in forum Linear and Rotary Motion
    Last Post: 07-28-2017, 01:55 PM
  3. Z-axis - mounting rails on spindle side, rather than tower side
    By guru_florida in forum Linear and Rotary Motion
    Last Post: 02-01-2008, 01:54 AM
  4. Which is better, round or square rails?
    By digits in forum Uncategorised MetalWorking Machines
    Last Post: 11-13-2006, 01:09 PM
  5. mounting linear rails side by side
    By 50062040 in forum Linear and Rotary Motion
    Last Post: 10-24-2005, 01:49 PM
