586,471 active members*
3,461 visitors online*
Thread: Need help
    Jan 2020
    Question Need help
    https://imgur.com/a/ptXQ5BV
    Is there an option to engrave inner lines and cut outer lines with Rdworks or some other software?
    Jun 2018
    362
    Re: Need help
    Not familiar with RDwords but with typical software and approaches you'd define two tool paths.
    The first as an engraving profile/contour with an engraving bit covering the outlines you want to engrave and the second for a cut profile using a cutting bit for the (outer) edge of the profile and cut them at the required depths.
    Other than RDwords, have a look at SimplyCam from MR-Soft Nc Software Tools for a different 2.5D drawing and G-Code generator program that can do this.
